Basic router bit set or more
Tom Dunlap
Finally, its time to buy a set of bits for my router. My projects have required a bit of edge work so I've bought a few individual bits. Now it's time to do some more complex joinery.
What set of bits would be a good choice? Either a list of bits or even a link to a favorite vendor would help.
How do I determine a good value? Some years ago I read an article about the variations in carbide quality. Since I have no knowledge about router bits I realize that less expensive bits aren't going to be a good value.
Re: Basic router bit set or more
del schisler
i buy what i need I belive that is still the best way to go You buy a kit and most never get used So the good buy isn't that good I have 5 routers and use them every day The bit's that i have were bought 1 at a time It may cost a little more ?? but it is what i use Not a lot of new bit's that never get used Figure out what you are going to do And buy the bit for that I buy amana bits I have a wood supply in the next town that carries all of them So i pick which one i need or to replace my take on this I Don't buy from the box store's Most are not for me
Re: Basic router bit set or more *LINK*
mdclor
Tom,
My approach is to purchase individual bits as I need them. I bought a set once because it was such a "great" deal. I think I have 3 from the set that haven't been used, so the ones I have used cost more than purchasing them individually. However, FWW developed a list of 10 essential router bits, see below. Infinitytools.com subsequently offered those bits in a set for about $260, IIRC.
There are a number of good manufacturers available, but I normally order from Lee Valley because of their overall quality of product and outstanding customer service.
HTH,
Merle
FFW 10 Essential Router Bits
Clint Searl, at the base of Haycock Mountain
Only buy the bit(s) needed for the project at hand. If you're going to run a bit more than 25 feet, get it with carbide edges. Solid carbide up cut spiral bits in 1/2 and 1/4 are handy for a lot of jobs. Onsrud are very good tools.
Clint
Good advice here, Tom...
doug f, san clemente, ca
These guys know what they're talking about. Buy the bits you need, when you need them. A set is not cheap if half the bits are never used.
I have Amana, Whiteside, Infinity and Rockler bits in my collection of about 25 and I use each of them at least a couple times a year, depending on the project. Get 1/2" shanks if your router takes them; less chance of breakage and less vibration.
Pick a supplier who has a good selection, buy quality bits and just buy what you need. In the long run, even in the short run, it's a much better deal.
Doug
The only "set" that I've bought was a "set" of straight bits. They were on sale. I use a variety of straight bits, so I bought them.
Other than that, I buy bits as I need them.
Gary Smyth
Over the years I have a lot of bits, more than I care to mention I�ve used on a single project and never again.
The bits I use most often are straight bits from 1/16� to 1� in numerous width increments and lengths, also the oversize and undersize plywood bits, and a couple of mm bits for peg holes in bookcases.
I use a wide variety of cove bits in the smaller sizes
And roundover bits in a set from 1/8� to 1� (on sale and never again)
Chamfer bits in various degrees, hinge bit, and flush and pattern bits in every length up to 2�
I have slot cutters, and shoe mold, picture hanging, core box, lock miter
I use 14 degree dovetail and the Leigh bits
All have �� or 8mm shank except for some of the smaller bits and all are carbide.
That being said, I have a lot of good bits from name companies. But it will take a miracle to get me to buy a set. I�ll go on a binge and buy duplicates or new to me bits at house sales if they look good. But there I�m paying maybe $3 a piece if that. Buy the bits when you need them or know that you will need them as a backup if you hit a nail or something. A set where you use three of five is not cost effective unless straight bits.
Good hunting.
My decision
Tom Dunlap
Thanks for the insights. This narrows down my initial search.
I'll look at the brands suggested. I'm likely to get several straight bits and at least one trim bit. Then it will be onesies.
Tom
Re: My decision
FredD
In addition to what the posters have said , if you haven't already , patronize a tool grinder that does saw blades and planer and jointer knives and Router bits.
I buy quality bits and many have had repeated sharpening by a knowledgeable shop that will not remove half of the Carbide at one pass.
Any bit I have seen hawked as made in China was a pitiful excuse for a bit.
Some bit manufacturers like Whiteside make house brands , I say if you want a Whiteside , buy one that says so on it.
Eagle catalogs list Eagle bits as made in America, I find this to be true, but they also push a Chinese product they call "Price Cutter" in each and every shape of Eagle brand they have for a few dollars less and not worth it.
Forget the crap you see spouted about the various new and improved Carbides just advertising hype . C-4 Carbide by any other name is still C-4 .
Stay away from bits that have a paint job on the head, it is there to cover up casting defects,
!/4 inch shanks are fine up to about a 3/4" cutter, beyond that I get 1/2" shanks.
Ask the tool grinder to hone your bits with at least a 400 grit diamont cup wheel, the good bits like Bosch wil use a 600 grit that looks like a mirror when new.
Cuts cleaner , runs cooler and stays sharp longer .
New bits that have less then 1/8th thick Carbide naturally will not last as long, Take a look at Vermont American and you will see what I mean.
Have fun
FredD
