12/4 Poplar "WIDE"
12/4 Poplar "WIDE"
12/4 Poplar "WIDE"
Wayne Carson
Looking for some wide 12/4 Poplar for a lowboy I know Poplar? I want to pratice on poplar before I try with Tiger Maple. And I have found out from Charles Neil how to make it look like Walnut and it does make some quilt racks out of the stuff. Put it beside some Walnut and really close. Any way looking for some 12/4 x 26 x 6' or two 26 x3' need to net width 23" could build it up from narrower pieces but would like it full width.
Re: 12/4 Poplar "WIDE"
background information, suggestion
Bill Tindall
Clear lumber only comes from the outside of a log. So, to get a piece that size would take a log something in excess of 32" diameter. In my life around mills I have only seen one poplar log that would yield such a piece of wood. It will take a band saw to saw it because circle saws typically can't saw something that wide. Band mills are associated with huge operations and they would sell such a log for veneer and not saw it. Of the thousands of bdft of lumber I have seen from commercial production I have never seen anything that wide in domestic lumber, except once a company got in some extraordinary wide sycamore, and that was about 1970.
It may be possible to find such a piece of lumber somewhere but it will be rare and probably pricey.
Suggestion: it will be easy to get that size in African mahogany and what you are making will look superior in that wood.
Thanks
Wayne Carson
I visit Charles Neils site and he is making a Bombe chest and I wondered how they come up with that size Af Mahogony does the stuff just grow the size of a small car, at one time we had trees that size must have been a site. Iv'e seen pictures of redwood and fir that size but not any hardwood.
It sounds like you wish to build the piece twice. The first one to practice before you use "good wood"? That's fine. But it also sounds like you are most concerned with some specific components and wanting to practice making them first...is that correct?
You might just consider making the piece with the "good wood" (tiger maple) to start with. But for those "tricky parts" you are unsure of just buy some 2X construction material from a big box, mill and glue up the blanks for the size you need and practice on that before you work with the maple.
It would be a cheaper route and less time consuming. Plus, if you buy the poplar and screw it up then might be frustrating.
Just a thought.
T.
Re: Thanks
Back Before the Chestnuts were wiped out they were the "Redwoods of the East". Some forests were 70% chestnuts and they were often four or five feet in diameter. Some of the stumps are still out there. What a shame. Saw a walnut log a couple of years ago on the back of a semi. Must have been seven feet at the butt and six at the small end. One tree was a complete load for the truck.
Suggestion
It's a fine old tradition to make maquettes or scale models before doing a piece full size in order to work out details and address unseen problems. It's interesting that many of those models by craftsmen and sculptors have survived when the full size pieces have been lost. Some are now worth large sums.
Easiest mode is to halve the dimensions; saves a lot on materials, and the machining and stuff is easy to translate without getting too small. Just remember that all measurements must be halved including thickness of the stock.
You can find poplar in 6/4x12 in most any good yard, but, as suggested, substituting 2x construction lumber will still save you a boatload of $.
Re: background information, suggestion
Bill Tindall
Some years ago I ordered some 16/4 mahogany for a customer and the 500 bdft pack consisted of 6 planks. Many years ago mahogany 48" wide was available. In the smoky mts I have seen 52" cherry and 6' poplar and other huge trees. But this kind logs have been logged out from about everywhere else. The last virgin boundary of timber I know of that was cut was cut in Clark's Creek near Greeneville, TN. I have seen pictures of the poplar logs, one to a log truck. I stood in chestnut stumps in this drainage that I could not reach across.
