Bleaching Black Walnut
David Frame Jr.
Hi all,
The natural color of walnut is a deep purplish color with black and dark brown streaks, be it air or kiln dried. I'd like to know how and what to use to make the walnut I'm usuing, to make a 3 in 1 transitional crib, that beautiful light to medium brown with dark brown streaks.
There is a bleach called oxalic acid, but there are many different kinds. Plus I need to know to how neutralize the acid. Can someone point me in the right direction on which brand of bleach to use and how to use it? I also ned more informatoin on the colorant to use. Should I use water or solvent based dye, gel stain, or the off the shelf pigmented stain. There are so many to choose from.
The walnut will not be filled with paste wood filler. After I get the color correct, I'll be spraying it with a satin water based conversion varnish.
By the way, does a childs crib need to have the hardware I've seen in woodworking magazines or can I make my own from wood and lift holes every 1", similar to a platform bed. This Sealy mattress is 6 inches thick. This is a custom job for my son and his wife. I have a grandchild coming into this world and we want the best for him or her.
David Frame Jr.
Re: Bleaching Black Walnut
Lee Schierer McKean, PA
Baking soda mixed with water will neutralize any acid including oxalic. I don't know what it will do to wood, but perhaps you should consider using walnut sapwood as it has the same grain but is light in color.
Lee
sun
Bill Tindall
Walnut, if unstained, will self bleach in a sun lit room to just the color you describe. Any bleached walnut I have seen looks awful.
I just completed a project using walnut similar to what you describe. I can only say that I have never subtracted color from walnut. I have only added color to it. Generally I add an amber/reddish brown anyline dye mix to walnut. Occassionally I will wipe a bit more on light areas but I general I find the contrast of heart and sap wood (after dyed) to be pleasing.
Tom
Tony - Memphis
I think I know what you are after and unfortunately, I don't have the answer. I noticed that Lonnie Bird's walnut pieces, or at least some of them, have that look. I asked him about his finishing technique for walnut and he didn't seem interested in telling his secrets. You might try looking at some of his articles to see if he mentions anything. Also, you might try Jeff Jewitt's Homestead Finishing site forum. Let us know if you figure out something. The colors on Lonnie's pieces are really nice. I assume they represent aged walnut (it lightens with age). I finished a lowboy a while back in walnut (my first piece in walnut) and ended up with it too dark. I used Van Dyke crystals to stain it to even out some of the color variation. Worked good, but the piece resides in a dark room and is way too dark. Looked great in the shop with lots of light! Got a picture here somewhere....
Tony
Just another opinion...
doug f, san clemente, ca
David - I've been working with walnut for almost 20 years, kiln dried and air dried. One thing I've learned is that you really need to pick and choose your boards for color before you start construction. I've tried bleaching; I hated the results, it looked dried and washed out, not like real walnut at all.
Over the years I've come to enjoy the myriad variations of natural walnut, from very light, almost white, sapwood, to the rich brownish red color. Choosing your boards carefully, you can achieve the color you want with just a simple clear or oil finish (my favorite is Waterlox).
Just my $.02; YMMV
Good luck with your project, it sounds like a lot of fun.
Doug
The secrets revealed
Bill Tindall
I think his walnut finish looks like crap. He bleaches to uniform color and then dyes with chromate. The result is a lifeless look preferred by few.
another thought
del schisler
I have been around walnut along with all the other hard wood most of my life I like what nother nature give us I don't do anything to walnut Just pick the boards I mix sap wood in also that gives the natual look If any other thing is done it's not what i like of course it is not for me Their is so much phoney look's out their photo finish ect. stain over cheep wood if it is wood press board most likey 2cents worth
Larry
Use some other wood that has the color you wan't. Don't bugger up black walnut. Bleached is ugly, kiln dried, because they steam it to even the color across the sapwood, is muddy.
Wood Bleaches
Howard Acheson
I'm not sure I understand why you want to bleach the walnut, but if you go ahead, you are using the incorrect bleach.
There are three bleaches used in woodworking.
o Chlorine Bleach (Clorox). This bleach is used to remove the color of a dye stain.
o Oxalic Acid. This bleach is used to remove mineral stains (black stains from water and metal) from wood.
o Two part A/B bleach. Used to remove the natural color from wood.
The last one is the one to use if you want to lighten walnut. Follow the directions on the packaging.
David Frame Jr.
Hi Everyone,
Thanks for the advice, but I don't think you see what I see. I think you guys should look at the book by George Nakashima, " Soul of a Tree." The color photographs of his walnut furniture is a medium to amber brown and it's absolutely beautiful. Sam Maloof is another woodworker we lost last year who knew how to get that brown color I'm looking for. Tage Frid is another.
My daughter-in-law would be very upset if I left the walnut natural or add a red brown tint to it. She wants a brown color. Nor am I thinking of butternut as an alternative wood to dye or stain a brown walnut color. Although it would be a good choice to dye or stain since it is the same gen
I love the natural color of black walnut. So far, all of the walnut I've made furniture with has been left natural 100% of the time. I have noticed over time with oxidation amd some ambient light, the wood does turn a natural dark brown. However, I don't have that much time to wait. My grandbaby is due in 5 months.
It looks as if i'll have to leave it natural and saturate the wood with an amber oil finish or a water based dye, dye gel, or do some experiment.
Thanks for your time, David Frame Jr.
David - I can't speak for Nakashima or Frid, but I do believe that Sam Maloof never used dyes or stains. His only finish was a concoction of oil, varnish and minieral spirits that he lovingly applied by hand and laboriously buffed. His secret, if you will, was having a stash of walnut the size of Texas stadium so that he could select his boards for color and grain.
I really believe that you'll be much happier just leaving the walnut to age naturally to the beautiful reddish brown that you're looking for. Besides, as long as the crib is comfortable the baby won't care, and the prospective parents will treasure it if it's made out of old orange crates and nailed together!
Have fun with your project and don't forget the pictures when you're done.
Doug
David Frame Jr.
Dear Doug,
Thanks for the encouragement. I think the walnut I have would be better served if I'd follow the instructions you and our other woodworking brothers gave me.
Thanks again,
David Frame Jr.
