Kitchen counter
Kitchen counter
Kitchen counter
Joey, New Canaan, Ct.
I want to install a 96" granite slab w a cut-out for a sink. Not concerned with the back splash. Can I do this myself? I am handy enough. Do they sell ready made at HD? Or should I go to a fabricator? I want nice, since I renovated the kitchen myself. Thanks, Joey
Re: Kitchen counter
Re: Kitchen counter
FredD
Unless your a experienced stone cutter ,I wouldn't advise it.
Huge opportunity to commit a expensive mistake.
FredD
Re: Kitchen counter
Re: Kitchen counter
paul in AZ
I'm currently looking at granite for a bathroom vanity.
If you are thinking of a drop-in top mount sink there is a remote chance you could rough cut that hole and the plumbing holes yourself without damaging the stone. For an undermount sink you will need a fabricator to accurately cut and polish the cutout. Go look at a fab. shop to see the machines they use and any thought of a DIY project will shrink.
As to premade counters, HD is not a good choice. Expensive, very limited choices of mundane granite and they farm it out to a local fabricator anyway.
In my area there are 2 places that sell premade 8 foot counter top blanks for $350-400 plus a charge for the cutouts. Limited selection but the price is better. Search the web or call around.
A good bet is to go to a fabricator or three and look at their 'boneyard'. These are left over partial slabs that they cut and finish for $30-45/sq. ft. including installation in the PHX area. Better than buying a whole 6 or 7 by 10 foot slab and using 1/3 which is is not only pretty expensive but your leftovers become the next guy's bargain. The fab. shop is basically giving you the granite for free and charging for the fabrication which includes gluing up and milling the edges, cutting and polishing the holes. If the boneyard piece is large enough they will add a backsplash for the same price. There can be some lovely and expensive stone that someone else paid for. Worth visiting several fabricators.
Granite is endlessly variable and the tough part is finding a color/pattern that works for you.
good luck. Keep us posted.
Re: Kitchen counter
Re: Kitchen counter
Paul thanks for the advise. Will do as you say.
I have another question, if you don't mind?
The installation is in a 1900's cottage. I put the kitchen in an area where there wasn't one before. The window sill is 6" below counter height. The sink will go in front of the window. So as not to block the window anymore than it is, I thought to use a low profile back splash. Maybe even 1/2 round granite, like a baseboard shoe. Is this a mistake? Should I just go with, like a 3" back splash? Joey
Re: Kitchen counter
Re: Kitchen counter
Thanks for the advise. It's bad enough making mistakes in wood. Joey
Re: Kitchen counter
Re: Kitchen counter
paul in AZ
I really don't know. My previous house was built in the 1880s [not here in Az where almost nothing is that old] and had just that low window behind the sink. As I recall there was a conventional backsplash on the counter.
Some if not all of the fab. shops have someone who may not be a formal design consultant but will advise you on solutions for problems like this. This has to be a regularly recurring question in New England's older houses. Something to discuss while looking at stone remnants in their boneyards. Talk to several of 'em.
Even if you are not going to buy a complete slab, the slab shops should have someone who can offer an opinion on this.
Once you have picked a granite from a boneyard the fabricator will likely come out to do precise measurements for the templates and/or computer guided programs they use for cutting and can look at the situation.
Re: Kitchen counter
Re: Kitchen counter
joey
More useful information. If your wondering why I just don't change the window? Because, it is double casement with lots of old rippled glass.
I'm bothered by the well created behind the present 4" formica back splash. It hides my period brass window bolt. When it's done I'll send you a pix.
Can I eliminate the 3/4" plywood under underlayment, to help shrink the well?
My wife would eventually like to move to Az., when we retire. Did you move from the East?
Thanks again, Joey
Re: Kitchen counter
Re: Kitchen counter
FredD
If it wouldn't be convenient height wise , how about dropping the cabinet in the sink and window area six inches.
Sounds like about table height which would be just peachy for my 5 foot tall wife.
On the other hand , it may cost you some prospective buyers ir you put it up for sale.
If that works , check to see if you can raise the window stool any , which would reduce the amount you lower the cabinet and if possible , for the best looking arrangement , run the counter top right onto the Stool.
Also a top mounted sink will help you to stay clear of plumbing hookup problems , especially if you have a disposal.
In my opinion , after designing and doing Kitchens for a long time , if the counter runs higher then the window stool or window , it never will look right .
FredD
FredD
FredD
Re: Kitchen counter
Re: Kitchen counter
paul in AZ
That 'well' behind the counter will never look right to those who after a modern look but will be accepted by those who know an old house for what it is. A bit funky.
Two options come to mind: the sink will probably be in it's own cabinet section. You could as suggested make that cabinet lower so that the counter is in two levels with the sink at the window sill height. That could be too low functionally for anyone of average or taller height and present plumbing problems. It could look very odd and be a turn-off to many when you come to sell the house.
A drastic option would be to move the entire window up 6 inches.
Or live with that well behind the splash.
Depending on whether you use 3cm. or 2cm. stone and the cabinet's support for the granite the decision to use 3/4" plywood or not will be the fabricator's. Granite may be very hard but slices of it fracture easily.
Rather than using space here drop me a note at paul2s@cox dot net if you wish.
Re: Kitchen counter
Re: Kitchen counter
Hamish
Joey,
In my sisters house, her kitchen top is higher than that of the window and it looks all right in her older house. Further more, not only does it give access to lifting the window to open it but she also uses it to house some plants which give a real touch to her room.
As for another idea for a back splash. You could make it our of a strip of laminated glass, rounded over along the top so as not to cut your arms when you reach over it, which would keep the water in and let the natural light come through too. It could be cut the same height as the granite back splash to continue the line across the window.
Just an idea, Hamish.
Re: Kitchen counter
Re: Kitchen counter
Thanks for everyone's design suggestions. Things I hadn't thought of and I always think I'm so smart. Hello!
The window is too old to move, since I recently rebuilt the rails. Well the well will stay. The back splash will go. Thanks everyone, Joey
