We value your privacy.
The key which locks the pulley in place on the spindle of my jointer motor came out and the slot for key is now misaligned. Even with the pulley set screws all the way out I can't remove the pulley to align the slots. I can't turn the pulley on the spindle without also turning the spindle.
Any idea how I fix this? Doesn't seem like it should be tough.
I used to have a cheap stamped pulley on my TS motor and the key would disappear about once a year.
You might try soaking the shaft with penetrating oil or PB Blast or a mix of Acetone and transmission fluid and wait a while. Use a pulley puller to extract the pulley. the pulley probably slipped on the shaft and called it. You may have to file or smooth the shaft.
To keep it from happening again I finally learned to soak the setscrew and key in Loctite. You can also put a second set screw on top of the first one in the same hole. Have you checked yours for a second screw under the first one?
Great, Gotta love it when a plan comes together...
OOPs... Just reread my post to see if I mentioned WD-40 and noticed the spelled checker changed gauled to called. Spell checker thinks Gaul is France. Maybe the word I am looking for is gall??? Was the shaft scarred?
Glad you got it. The Locktite was critical for mine. Before I used it the key came out almost routinely. Eventually I replace the pulley with a machined one.
I think you must have mixed it up in the back of your mind with "caul." English is SUCH a logical language - inevitable, I guess, for a language assembled from spare parts of lots of different languages.
I'm not sure what it would mean to be "gauled," though if it involved Brigitte Bardot, Catherine Deneuve, or Audrey Tautou, I might be willing to find out.
Re: Great, Gotta love it when a plan comes togethe
Stephen Kirk
I'll keep an eye on it, make sure it isn't coming loose again and loctite if need be. I'll be back out in the shop soon on a project that'll need a bunch of jointing.
Didn't seem like it was galled, still felt pretty smooth. I noticed that the threaded locking thingies (really don't know a name for them) had been working loose which let the key out.
I'm happy it wasn't something more serious. like requiring a motor replacement.
Obviously you don't know any French people as well as I do. If you did the idea that "Gauled" would equate to a shaft that had been abraded and rubbed the wrong way would make perfect sense.
