Just curious - vanity "floor" question
Terry Alexander
Why is the face frame on a bathroom or kitchen vanity supposed to be "up" 1/8"?
Sure makes it a pain when building them....but just curious as to why it isn't dead even with the bottom/floor of the vanity.
As always....TIA
Terry Alexander in West Texas
Re: Just curious - vanity "floor" question
Not sure what you mean
I don't know of any rules that say face frames should not be flush with the bottom of the cabinet. I never built them that way. Maybe cheap cabinet companies do it so they don't have to worry about being too accurate with their sizing.
Where did you get the idea that there should be an offset? Am I reading you right?
I don't understand the question
Bill Tindall
"up" from what?
I don't think there is any reason for it. Actually, I can think of several. It makes the vanity hold water so you have a chance to catch a leak before it runs out into the floor. (Not a very good reason.) It makes it easy for the owner to install a piece of vinyl flooring in the bottom of the cabinet without interfering with the door. It is easier to install the frames consistently if there is a little "margin for error". The bottom might be rabbetted into the front? And.....
But the answer is, if you are building your own, and you don't want the lip there, do it your own way.
FredD
Terry ,
When I make a vanity or a Kitchen bottom cabinet , I notch the end panels for a toe kick and have the notch extend down past the vanity bottom a half inch.
This gives you a bottom rail for the face frame a 1 1/4" in width assuming your using 3/4" plywood for the bottom.
Having a wider rail then the Vanity bottom is thick gives you a detail and a remaining surface that shows , even with overlap doors.
There is no reason to extend the bottom rail "up a 1/8th " that I am aware of and I have made a few cabinets .
FredD
FredD
ash Sioux Falls, SD
Mine are flush . . . plus they have high pressure laminate on the bottom interiors.
Kirk (KC) Constable
I've always thought it was to provides a little stop to keep things from sliding out as easily when you reach under there for the Comet... but when I build a cabinet like that or a display cabinet that might hang on a wall, I'll do it like that so I don't have to worry about making the 'joint' look good.
