semi OT Java
John Veerkamp, Western Mo
I have two versions of Java on my PC,used for our chats. Versions are Java Runtime Standard v 1.3.1 and v 1.3.1_02. Is it safe to remove 1.3.1?
Thanks,
John
semi OT Java
Thanks,
John
Re: semi OT Java
Grant Wilkinson
You can remove the older version. Both of those are very old and you should consider upgrading to the newest version, which is the the version 6 family. You can find it on java.com. When you update these, the older version is not automatically deleted. You can go into add/remove programs and delete it manually.
Secunia Online Software Inspector *LINK*
David Yoho
John, you always want to remove any older versions of Java. I'm running the most current version, which is Version-6 Update-18.
In case I haven't mentioned it in the past here, there's a free online scan you can run to check for out-of-date programs on your computer. This includes Windows updates as well and provides links to the most current updates for each. I check mine on a regular basis but also have Secunia set to email me a reminder.
Try the Secunia Online Software Inspector (OSI) and see what you need to update. Keeping the current updates installed is another step in securing your computer from the bad guys.
