Delta # 11-990 12" Drill Press
George Colonel's Workshop-Havertown PA
Good Afternoon Friends,
Perhaps 4 years ago I bought a used Delta Drill Press from a friend. It was in good shape, worked well when I tested it, and had no rust. I gave it to #1 son. He has given it moderate use until he noticed run out. I removed the spindle assembly and chuck. Called Delta and they indicated the problem was probably the spindle, which they had for sale for less than $20. I was reluctant to buy the spindle since I didn't know it actually was defective, and Delta and I each agreed the problem could stem from worn bearings and a bad chuck. The Delta tech rep still guessed it was a bad spindle. However, I elected to take the parts to the Porter Cable Service Center in South Philadelphia and let them tell me which component needed replacing. I waited two weeks. They told me I needed to replace all parts at a cost of $90.00.
Of course I don't know for sure, but my instincts are that all they did was to price the cost of all parts and add in their labor. Maybe I have a suspicious mind.
I think maybe I should order a new spindle from Delta, and install new bearings from Delta or Grainger. Not sure what to do about the chuck. My guess is that I can do it all for a lot less than $90. Comments?
George
