We value your privacy.
Yet another electrical question... Ground or not..
Grounded plugs versus non-grounded plugs.
We all have lots of non-grounded plugs (lamps, small appliances, etc.). We all have lots of grounded plugs.
I've got some of my stepfather's old tools that don't have grounded plugs. I'm not using them currently because I have my own tools. I also have his older extension cords that are still in decent shape. Again, I'm not using them because I have my own cords.
So the question - should I use tools/equipment that are not grounded? We're not talking high amperage - maybe 5-6 amps for the tools. The cords are 14 to 12 gauge.
The tools were used for many years - and I'm contemplating donating them to our community theatre. If ya'll think it may be a safety issue, I'll just keep them as backups.
Re: Yet another electrical question... Ground or not..
Bill Howatt
If the tool has a 3-prong plug on it, that is, a ground pin, then it should be used with a 3 wire cord/receptacle that is grounded. With tools that are quite old, it is possible to find them without a ground pin. If the tool body is metal then ideally the metal frame should be grounded; if it is plastic, then it probably is in the double-insulated category.
Old metal tools could be rewired with a 3 wire cord and plug but it would mean taking the tool apart and finding a place to connect the ground wire.
You can make the 2 wire tools and cords safe to use by using a Ground Fault Interupter receptacle. It will protect you against the tool becoming "hot" and trying to fry you without a ground wire. Perhaps, not the ideal situation but a whole lot better than nothing by a long shot. In addition to having GFI receptacles in your house, you can also by short extension cords that have GFI protection built in which makes them portable if you are working away from home.
Whether or not the people you might donate them to would consider them useable is something only they would know.
Bill
Howard Norman
As I read your post I visualized the old metal case power tools with a two terminal cord of the 40's and 50's vintage. If it was me I would replace the two conductor cords with a grounded cord with the ground fastened to the metal case of the tool.
I would not donate them to the community theater without making that change. Just because they are only 4-5amp tools doesn't mean that they can not be lethal under the correct circumstances.
A lot of the old metal-bodied tools were built in an era when the standard plug had two slots, but the metal box was grounded back to the panel, and the screw in the center of a duplex outlet (the one that holds the cover plate on) was thus grounded. My comments below apply to these tools ONLY.
As a way of grounding these tools, they sometimes (not sure how often) came with a little pigtail hanging out of the plug. You were supposed to loosen the cover plate screw, put the terminal on the end of the pigtail under the screw, tighten it, then plug the tool in. You then had, in theory, an equipment ground.
You can be confident that every tradesworker and weekend worrier did this every single time, after first checking that the screw in question was indeed grounded.
For some odd reason, these pigtails often disappeared; you can sometimes see the remnant of the pigtail sticking out of the plug (if it's the original plug) somewhere, such as up at the cord end.
If the cord's in decent shape, you can cut the plug off and install a proper three-prong plug, after checking with a multimeter that you've got equipment ground from one, and just one, of the wires. If it's cracked and used up (a far commoner state), you can open up the tool and confirm whether you've got equipment ground, in which case new cords are about $15, cheaper if you've got an extension cord on which one of the ends has gotten bunged up.
Regardless, I wouldn't recommend donating them to your theater group. While these are often durable as can be, you don't want to put them in a setting with people who may not know enough to detect a tool that's failing and who might run it until it loses all its smoke and injures someone in the process.
The plug adapters with the ground wire are AFAIK illegal in Canada. The reason being is that the wire feeding many of the 2 wire receptacle boxes didn't have any ground in the first place and the tying the ground wire to the screw did absolutely nothing in terms of providing a ground in many cases. This wouldn't be obvious without getting a meter and checking the screw which I would be certain to do if I were relying on it. IIRC, I had an older house and the 2 outlets in the kitchen did have grounded boxes but elsewhere in the house they didn't.
