Test
Test
Test
Barbara Gill, Remlik VA
I am unable to post on the Turning Forum and thought I would try over here.
Re: Test
Re: Test- Works Over Here
Re: Test
What happens when you try there?
Dan Donaldson
Re: Test
Think I found it
Dan Donaldson
I fixed them so you should see them now. What it looks like happened is that there is a link in the body of the text rather than being entered in the url box. This tosses it into moderation and it has to be approved before it will show up.
Re: Test
Re: Think I found it
Barbara Gill
Thanks Dan. For some reason the link box never showed up as it usually does.
That is why I put the link in the body.
Re: Test
Barbara, I see your name appears no as a link to your profile, where it didn't earlier in this thread. I think I read elsewhere that not having a profile set prohibited pasting a link into a message. If you've edited your profile, you might try posting another message with an embedded link and see if it works now. JKJ
Re: Test
As I mentioned...
If the Optional Link URL box doesn't show up when you try to post a message, it means the usernamd ("Your Name:") is not linked to a profile, and therefore you may not post a link. In your case, Barbara, your profile was created with the name "Barbara Gill." When you added "in Remlik, Va", our system did not recognize you as a registered user, hence your message with a link was intercepted.
If you want to change your username to "Barbara Gill in Remlik, VA" (or anything else) and retain your registration benefits, you need to make (and save) the change(s) in My Profile. This resets your cookie with the new name.
If you sign on from another computer or browser later, you must use the same name and e-mail address as you created in your profile, or else you won't be recognized.
It's really a lot easier than it may seem. Read the FAQ page any time you need help with this.
Re: Test
Re: As I mentioned...
Barbara Gill
Yes,I think I took care of it this morning.
