Electric Stapler???
Thomas Norton
I need to buy an electric stapler. I will be using it for a radiant floor heat project stapling up aluminum panels and insulation.
So I need some recommendations.
Thanks
Electric Stapler???
Thomas Norton
Thanks
Re: Electric Stapler???
Clint Searl
Arrow electric. Senco air for heavy duty.
Clint
Dan Donaldson
In a galaxy far, far away.... I used to do radiant heat with the heat cable once in awhile. Based on that, I would think about air driven staplers if the job is on any size. They are lighter and work much better. You can run them with a small pancake compressor that you can buy or rent for not too much.
I briefly owned an Arrow, but took it back
It jammed frequently and often. I bought another T50 hand stapler - not as easy on the hands, but far more bulletproof.
Ours exploded....
John in NM
And broke a window pane. It was a pretty cheap one, an Arrow I think. Never worked well either, I was always having to hit it with silicone spray. I'd bet you'd need a pretty heavy duty unit to go through aluminum, ours wouldn't have done it - but my pneumatic will.
Had one, thru it away.
Phil Joines
Used an Arrow that belonged to a friend, was not impressed and would not buy one.
Pneumatic is the way to go.
For the insulation look into a Hammer Tacker or slap stapler. I have one that I have had for thirty years. Bostitch I think. It might work on aluminum too it the aluminum is thin.
BilWil
The advice you've gotten to go with an air driven stapler is good. I bought one about 4 years ago to do a job that was small enough I didn't want to set up the compressor and run air hose. Two things I learned: 1. air staplers don't last very long and they jam with some frequency. 2. Dragging the cord is about the same as dragging air hose. I'll never do it again, well, sometimes I don't learn after just one experience so let me say I hope to never do it again.
