auto a/c reconditioning?
Joseph Mulherin, Sr
A question to the collective: what would I use to flush the a/c system prior to refilling with new R134 fluid? My Van went without any a/c last year. I went to the local shop to have it examined and he said I had a combination of R12 and R134 and things were just totally contaminated and he wanted to replace everything from the compressor, condensers, and the entire tubing and valves....about $1,000 in all ....at todays prices. Now, I have researched about the flushes available to buy, and will use one of them after I flush the system myself with another solution....my question is what to use. I also plan on replacing the o-rings on the compressor because the heat destroys the o-rings over time and that i9s one of the main reasons the compressors fail us.
Re: auto a/c reconditioning?
DouginDenver
You said you have researched flushes avialable to buy, and will use one after you flush with another solution. I don't understand that. Do you mean you have researched recharging kits you can buy?
Anyway...
DouginDenver
Do some research. You can't flush every component. People have used all kinds of solvents - even mineral spirits. But something called Dura 141 is a CFC free solvent recommended for that use.
Re: Anyway...
Joseph Mulherin, Sr
Thank you, Doug, I shall attempt to find and buy some of the Dura 141b.
Re: Anyway...
Joseph Mulherin, Sr
I have downloaded many pages on the flushing of the system. Plan on removing the compressor and replace the o-rings and gaskets to be acceptable for the R134a fluid, replace the proper oil with I think Porter; remove the condenser and flush; flush the evaporator in place; flush the hoses also;replace the expansion valve and accumulator if needed ....probably so. But at the $1,000 quoted to me this seems like something I can do myself and then take it to a shop and have it evacuated and refilled.
Yeahbut
When you go to that "shop" don't be surprised if they decline the job because, since they haven't done the flush/rebuild/replace parts of the job, they don't want you coming back with complaints when it doesn't work.
You might do better to shop around for a better price if you can't do the whole job yourself.
Bill Turpin in WNC mountains
How did this mechanic determine that you had a mix of 12/134? The freon is a vapor at room temperature and will boil off if left open. What was the original freon? The mechanical components of the systems are not compatible. They use different oils. The expansion valves are different. If this system has been charged with both freons, the oil should be changed, this is low vapor-pressure refigeration oil, not Quakerstate. Freon and refrig oil dissolve each other. The entire inside of the system will be coated with oil. Some re-charge kits (cans) contain small amts of oil. The two oils make a nasty semi-solid after mixing. This crud will stop up small orifices.
I would recommend, after putting system back together, run a few minutes, and blow the charge and oil again! Your flush will not get everything. If your system spent last year leaked down, then there is no freon there for your mechanic to mis-test! Do you really trust this guy?
Bill in WNC mountains
Retired NC Refrig. Contractor
Joseph Mulherin, Sr
Bill, that is a very good question....and he did not state how this would be determined. The original system was Freon 12, was flushed out and 134 valves were installed and recharged with the R134a fluid. I believe the compressor has a leak in the shaft seal and that what I am going to repair and do the entire flushing while the system is apart and open to rid the inside of the tubings of everything...total cleansing I hope.
And, like Mark just said, the shop I go to might refuse to do as I ask in vacuum evaculating the system and recharging....that I will contend with after the system is flushed and repairs done on the compressor. But I do realize the entire oil has to be cleaned out and use the proper oil for the 134 system.
I am retired on only socsec and do not have a bunch of money to put out on this older Van, and cannot buy another either. If everything I do does not work outas expected...I am not any worse off than what I am now.....
Lee Schierer McKean, PA
Your first problem will be finding the leak that lost your previous charge of refrigerant. Failing that you are wasting your money on a new charge. You can pressure test the system with clean nitrogen and not do any damage. You'll also need a good gauge to watch for pressure decay to determine if the system has any leaks. The refrigerant oil will absorb moisture so if the system has been opened or will be opened for any length of time the oil will be ruined. Air from your compressor will contain lots of moisture so I wouldn't recommend your shop compressor for pressure testing.
You may not find a refrigeration dealer that will evacuate your system so you can recharge it.
Lee
Did the converted system ever work properly? If it didn't then do not go further. I would not be too concerned that you have mixed freon. A competant service person can check liquid freon, its pressure and temperature relationship to determine if it is mixed. Since the oil ALWAYS travels with the freon, there will almost always be an oil slick at the leak. The slick then attracts dirt which is easy to see. Leaks around the shaft makes it hard to see. Does your mechanic have an electronic leak detector? Most of them are accurite to a half oz per year.
If you get to a vacuum and recharge stage, pull a long vacuum (at least an hour with fresh oil in the pump). Also do a triple evacuation: vac, put enough freon in to a positive pressure, Vac, again. Do this three times. ONLY one drop of moisture in your system will kill you. Your are trying to boil that water at room temperature, it's pretty tough. Use the shortest vacuum hose possible. The speed or volume of the pull down is inversely proportional to the square of the length. Twice the hose, FOUR times the time to achieve the vacuum. Are the bearings and the shaft seal combatible with the new oil? Do you know the crankcase capacity of the compressor. Most recharges consider that there is still enough oil without adding more, but with your cleaning, you will need to know.The last time that I knew (10 years) the oil was $30/gal wholesale. You will probably need about 48 fluid oz. Charge the oil with the compressor off the vehicle.
Bill
Re: auto a/c  R-12 and R-134 are
Dave (PacNW)
Not compatible or interchangeable. Neither solvents or system components. The flushing solvent is EXPENSIVE expect $80 to $100 per gallon! Then "IF" you can find R12 Expect $40 per pound R-12 was outlawed several years back, but some is being smuggled in from Mexico. There were some after market kits to convert to R-134 available a few years ago, But they didn't work very well. Call several Auto A/C specialists and get second opinions As always this advise is worth what you paid for it!!
Dave (PacNW)
Joseph Mulherin, Sr
Yes, Bill, the system did work for about a year after the conversion. I do believe the leakage in in the motor shaft o-ring. Like Lee said I am going to pressure the system with dry nitrogen and determine exactly where the leak is and repair as needed. I tried the leak detection fluids and could not discover exactly where the leak was. And changing the oil is positively going to be done. I do have the gauges for recharging, but need a vacuum evaculation to the mear 30" done before the recharge...hopefully I can find someone that will do it for me
at a reasonable cost. If there is anymore leaks I will not consider the shop at fault.
If there are much of a leak/s you will not get to the 30".
Joseph Mulherin, Sr
Yes, Bill, I understand....pinholes in the condenser, cracks in the hoses, leaking thread fittings...all of these I understand...just have to start with the pressuring with clean nitrogen and a leak detector solution and hopefully I can find exactly where the main leak is and repair as needed. I am a retired pipefitter,plumber, worked on a/c systems during my career, but the auto systems are a new animal for me. Thanks for the advise everyone......
