We value your privacy.
I'm testing Verizon wireless connection looking for an option to dial-up. No DSL or cable available.
1) What is a good site to test for free my access speed?
2) What can I do if anything on my pc running xp home edition to improve performance. Would increasing the size of the temp file cache help any? If so how do I do this?
to test your speed, www.speedtest.net, will do it for free
as far as the cache, very few people use anywhere near the default cache level unless you are a real heavy internet user visiting hundreds of different sites a day. Nine times out of ten, the computers I work on that are complaining of slow internet, I find that there are spyware programs running in the background that eat up internet bandwith. Went to somebody the other day and ran SpyBot on their machine and it came back with over 1000 different spyware and adware programs running.
Yikes, were these all actual active programs running that showed up in taskmanager as processes or as services, or were most the tracking cookies the checker programs always uncover?
John, as for your performance question, can you be more specific? When most people say their computer is "slow", they are taking about internet performance. Is that what you mean or is performance slow in general - does the computer take a very long time to boot and shut down, slow to start programs such as Word?
As for cache file size, does the hard disk "thrash" (watch the light - constant access?) when you try to do almost anything? Did you examine the resources in Task Manager to see how your memory is being used and which processes are hogging the processor cycles?
Have you installed a bunch of stuff? (My rule is to remove most of what comes pre-loaded on the machine and only install what I absolutely need.) There is a great little free program called Startup Control by Mike Lin which will let you see what programs are being loaded in the background at boot time. Note that programs can be loaded by the registry as well as the Startup folders.
Did the computer used to run faster? One way to fix things is to backup everything you want to keep, then wipe the hard drive and reinstall the OS. Make a note of what services and processes are running just after the fresh install (for comparison later), reinstall all of the software you really need, restore your personal data, then compare the processes and services to the original. This will give you a baseline for future comparison to help identify unwanted software.
If you don't have time or inclination, there are people who will do all of this for you for a fee.
I wasn't counting the tracking cookies and such, On the task manager there is a check box that states show tasks from all users, that's where i found out that he had a problem, they were running under a different user context and everything that John said is good to check too. watch what some stores will tell you though. Increasing RAM is a cheap fix for some slow problems, but on XP unless you got one of the few 64bit versions, which wasn't widespread till Vista, then the operating systems cannot access anything beyond 4 gigs.
I have Verizon and it is blazing fast compared to the satellite service I had. Click the Verizon Icon on the tool bar and look at the signal strength under "Statistics" or put cursor on the place that has the bars and look at signal strength. The statistics section will provide data on your connection quality. I average around -80db and my downloads for pages is nearly instant. If you can't figure out the statistics page email me.
My connection looses its mind periodically and I have to reinstall the receiver to reestablish a 3G connection. So, keep track of your signal strength and if you suddenly loose your 3G connection, reinstall or call Customer service and they will guide you through the reinstall process.
Removing the receiver while the computer is on will cause it to loose its mind.
A quick look at the Verizon wireless page says maximum download speed of 1.4Mbps and typical, being about 1/2 to 3/4 of that. Unless your XP machine is really suffering from a lack of RAM or excessive junk running at once, it should be able to keep up to that download rate without much trouble at all. Remember, a typical home wired networking speed is 100Mbps.
the slowness I have a problem with is when connected to the internet. I've run spybot and have no spyware. Still max download with verizon wireless card is 121 kbs.
The speed you quote suggests you are not receiving a 3G signal. The statistics page will diagnose you situation. You can buy an antenna to boost strength, but first make sure you are connected properly. It is easy to screw up the install and if you do you will default to a non 3G signal even if you have 3G strength available. I have found the tech service at Verizon very helpful.
1st - run "msconfig" (run is in start menu). Go to the startup tab. Check everything that is being started at this site:
http://www.sysinfo.org/startuplist.php
Uncheck all items that are unnecessary.
2nd - click "Start", "My Computer", pick your main drive from the dropdown list that pops up and right click. Select "Properties" from that drop down list. Now select the "Tools" tab. Select the "Defragment Now" button.
3rd - You could add memory to your computer.
4th - Once a drive is above 70% full, performance deteriorates. If your main drive is above 70% you should consider getting an USB external drive and moving anything that's not software over to the external. I've seen some terabyte drives at unbelievable prices.
Thanks to all who replied. After hours on the phone it appears that this may be a coverage issue. They're sending an engineer out to check for signal strength. Maybe stuck with dial-up. At least Verizon is actively trying to help and diagnose the reason for slow internet response. Max tested speeds were .121mbs download and .044 upload. Not very promising.
