Shopsmith Mark V
Joe Smith
I would like some expert opionions on the Shop Smith Mark V combination tool. I see very little mention of it anywhere except the Shop Smith web site..
Shopsmith Mark V
Joe Smith
Re: Shopsmith Mark V
I started out with a shopsmith Mark V. It did not take very long for me to become weary of changing all the setups. It does various tasks well but not as well as separate tools IMHO. I found the table saw to be lacking in power and the small table was a problem for me. In fact I came to feel that the saw was somewhat dangerous. That's just my take. The accessory tools were expensive for what they could do.
All and all I think it's a tool for those who have very little space and only do small occassional woodworking projects.
Tom
Carol Reed
I had one for a number of years. It does get tiring changing the set-ups, but really challenged me was getting something all set-up perfectly and then fail to make enough parts of screw one up and have to repeat it later! With separate tools, the machine I need to repeat something may still be set-up correctly!
That said, I sold it. However, this question is like other tool buying questions about which tool is "best." The answer depends on what kind of woodworking you want to do, and you may not know until you do some for a while. It also depends on what you want to build.
A better question would be which features are a basic must-have for ...(insert the tool choice here). Then look at your limitations and adjust accordingly. Example, if your shop space is the size of the average walk-in closet, then maybe the Shopsmith is the right choice. If the space is to be shared, perhaps with the car, then everything best be on wheels.
Get the idea? So fire away, we're here to help, and the benefit from our experience is at the right price to you.
Joe Smith
Thanks for the input. I have been doing woodworking for quite a while without a shop. Since I haven't had a lot of time to spend I just drag the tools out when I get the chance, and then put them all back in storage until I get time for another project. I am getting ready to retire in a couple of months and will be spending a lot of time in the shop. Actually that is another project, building the shop. Space is not a problem. I am considering maybe 30' x 40'. I recently got a lathe but it is not a variable speed motor. That was I really liked about the Mark V. I'm also going to have to get a bette table saw. The one I have is about at the end. Got a drill press, but it is a bench type and I thought that Mark V might serve better. From the sound of two previous owners I would probably be better off investing in a good table saw and using the other individual tools. I plan to get more into furniture and wood turning.
Joseph Mulherin, Sr
Joe, I bought my Shopsmith in 1978 and still have it and use it for my projects.
As Carol said, I too have limited space and this tool does everything I need to have done in woodworking. Of course, I have other tools to do the routing, bandsawing and planing, but the Shopsmith is satisfactory for my style of working. As far as I am concerned.... you need to PLAN your wood working steps to take advantage of the SS capabilities....i.e. setup to do one thing entirely at a time before resetting for another task.
George Colonel's Workshop-Havertown PA
Hello Joe,
I do not own one, but have used one in several occasions. I like the IDEA of saving precious shop space, but your situation seems spacious. One Shop Smith feature I especially disliked was the table saw arrangement. It was hard to keep in precise adjustment, and it did not provide solid support to the work. The work also had to be small because the table size is very small, and has a lousey fence besides.. I did like the drill press, horizontal boring machine, and lathe features. They were smooth, albeit somewhat undersized. Still, I believe they provided a reasonable alternative to stand alone bench top tools. I could see myself equipped with a good stand alone tableaw and band saw plus a Shop Smith for most of the rest common functions. I prefer individual tools, so that is what I use. As an interim measure, a Shop Smith may be a viable choice in your shop until you can acquire more effective equipment. However, I would buy it used. I see many on Craig's list at attraxctive prices.
George
Joe I started with a shopsmith and it was a good tool for the space I had. I had a 10x12 room and was able to do a lot of work with that machine. However now that I have stand alone tools and more space I would not go back unless forced.
The MarkV has a lot of little quirks. The table is too small so you have to move the table and motor and use the secondary table for the fence. This often meant changing the settings and/or sliding the motor and table which was a pain.
The lathe is the worst part of the machine. The bearings aren't strong enough and the tool rest is too unstable as is the tailstock. This all leads to chatter. I turned a lot of stuff on it so obviously you can do it. However now that I use a good lathe when I visit my dad and use his shopsmith I can really tell the difference.
The problem with the drill press is the table isn't solid enough. If you force the cut by pushing hard on the drill bit the table flexes which can give you an inaccurate cut.
All in all I did a lot of work with it. My Dad has made many pie safe's, tables, and small jewelry boxes with his. His level of work isn't quite up to mine but he enjoys what he's doing and the people he gives the work to enjoy them.
I think what I'm saying is, if you have the space and money go with stand alone tools. You will be happier. If you don't have the space then the Shopsmith is the say to go.
Alan in Little Washington (NC)
I had a SS for 20 years, have individual tools now, and would NEVER go back. It was fine then because I moved allot and had limited space. I don't disagree with anything said here except thing the TS feature is worse than lathe. It is not only bad but downright dangerous - to cut a bevel you must tilt the table!!!
New ones are WAY over-priced for what you get, so If you decide to get one, buy a used one.
One other consideration- There have been a few reports on various forums and from a third party repair guys that SS filed for bankruptcy a few months back and released all employees. The reports go on to say that Robert L. Folkerth, the previous CEO, is trying to start up again under a new name "RLF Shop." A Google search for Shopsmith failed to shed any more light on this or their current status. Financial reports show them losing money big time most of the previous decade and some analysts predicted they would go under. They sold their 120,000 sq. ft. building in 2008 and were leasing back only 40,000 sq. ft. of it.
From a business link ; "This was Covington Capital�s first Dayton-area property, but it wasn�t its last. In November, the group snatched up its second building in Dayton, the 120,000-square-foot Shopsmith Building at 6530 Poe Ave. "
frank ashmore
As most everyone else has said ,stand alone machines are the best way to go.
Just more precise.With a 30x40 shop in the future its a no brainer.You will enjoy woodworking much more with dedicated machines.And really you have to tilt the table for a beveled edge?
That sounds suicidal!YIKES
Smithy super shop
This is a heavier duty machine than the Shopsmith. I don't know much about it but I have a Smithy Lathe/Mill and the company has been excellent helping me get it set up and tuned up. I bought it used. www.smithy.com
