New Shop Questions
New Shop Questions
New Shop Questions
Allen Bryant
Been a long time since I've been on here, addition of a second child, changes at work and a significant illness (resolved) have kept me out of the garage work shop for a while. My wife has decided that she wants to take over the section where my shop is currently and that means a new shop for me. I am going with a 30x30 building with a raised wooden floor, the question is what do I use for the floor material. Do I leave it with just plywood or do I cover the floor in something and if so what could I use to make it easy to clean and durable enough to stand up to being in a wood shop.
Re: New Shop Questions
Congrats
I always envy people who are building a new shop for themselves. Regarding flooring, I built my shop ten years ago using t&g 3/4" plywood for the subfloor and never did get back to laying another floor over it. I painted it when it was new with an oil-based primer and it is still holding up fine after 10 years. The nice part is that you can always put a fancier floor over it if the mood strikes.
Cheers,
Carol Reed
3/4" T&G Sturdi-Floor. It is a chip board product with a 'finished' side. Easy to paint and intended for the job.
The first shed had a plywood floor. The next one had this stuff. Much tougher.
FWIW.
FredD
Allen ,
This shop is the last one of several I have owned and the floor is the result of a lot of thinking about tired feet and legs.
Over a six inch concrete slab , I laid 2x4 sleepers flat 24" o.c. and over that I laid 241 plywood, 1 1/8th thick, bonded to the sleepers with PL 4 construction adhesive.
For the finish I wanted a cheap easy to install and keep clean material and I cut 15 & 7/8" square tiles from tempered Masonite and after consulting with the lab guys at Porter Paint, rolled a two part Epoxy paint on the tile.
Proter told me they had a Safeway store with that paint down for ten years and no noticeable wear.
This has been down since 98 and like they said , no wear.
It is a very hard paint and the roller gives it a non skid texture.
One suggestion for buildings like that, I try to keep the OD dimensions such that plywood siding and sheetrock comes out even.
Like say 32 x32 ;-))
Allen,
Post some pictures of the progress!
My last shop was bare plywood and it worked great. I used rubber mats where I stood at the major tools. Never got around to painting the floor.
At this house my wife wants her garage back. At the moment my own new shop is some cleared ground and a big hole (I'm putting a basement under the wood shop half). I hope to use hardwood over plywood if I can saw and dry enough in time.
Clint Searl
3/4 T&G Advantech
Clint Searl
Re: My solution...
Royce
When I built my shop I thought about what finish to put on the plywood floor. I decided not to do anything with the bare plywood because...
Over time I am building up a nice finish of spilled paint, stain, polyurethane, etc.
Allen Bryant
hmm, bigger shop to make the plywood even out..will have to try that.
Joseph Mulherin, Sr
I like Fred's idea of using the tiles over the top of the plywood....and if necessary you can replace easier each tile if it get nasty in some fashion. Before building you new shop, I suggest you try to use the Google Sketchup program and make a picture of just what you would like to have in the building. This is easier to change without wasting valuable funds on correcting a mistake later.
Paul Kramer
What I did
Paul Kramer
I did mine a lot like Fred. I laid 1 X 2 PT sleepers on the concrete about 12" O.C. Over that I laid 2 X 6's on edge also about 12" O.C. Then a layer of 3/4" plywood and finally a layer of 1/4" tempered hardboard. Then I painted with a light grey floor paint with the grit in it. I've had it for about 7 years and it's holding up well. I use the space underneath as a chase for running electric and dust collection.
Paul
