Cast Iron Router Table
Jorge Casta�eda
Hello,
I remember reading about a cast iron insert for the right side of the table saw, (replacing) that I thought was neat because it does not eat more shop real state, but I cannot remember who makes it.
Do you know?
Thanks
Jorge
Re: Cast Iron Router Table
Look here  *LINK*
Dan Donaldson
cast iron router tables
That's the one!
Jorge Casta�eda
Thanks Dan.
That was fast.
Jorge
Re: That's the one!
David Hay Denver
I have one of those and find it quite useful. I have it mounted on the left side of my table saw and moved my existing cast iron wing to the right side. However I believe you can mount the router table to the right side of the saw, if you wanted to.
Re: That's the one!
Jorge Casta�eda
Hi David,
In my saw the only option is the right side, there is a big box in the left, the space the motor goes when on tilt.
But thanks for the info, much appreciated, feel better spending he money when I hear that somebody that has it likes it.
Thanks
Jorge
Keith Newton----Little Rock, Arkansas
Jorge, you are not giving much information about your saw, but I would just offer what I did many years ago. I have a Powermatic # 72, which is a pretty big saw, that has a solid cast table 50" to the right of the blade. The underside has a grid of about 8" square ribs.
I don't remember how many years ago, I used a lenox hole saw to mount 3 routers under that big wing for a pretty good size plexiglas template routing project. It was kinda like having a Ritter 3 spindle shaper, uh,,,, router.
Most of the time there is only one router under there, but all it takes is a hole saw to cut through a cast iron top, if there is enough room for the base of the router between grids. And if there isn't, cutting out a grid isn't all that hard.
Jorge Casta�eda
Thanks Keith,
I have an old 10", 2HP JET cabinet saw, that has a 27"x40" cast iron top, the wings are 27'x 10", the router I want to use is a 3HP Hitachi, to accept that I would have to cut through a number of the ribs underneath and leave little metal. I don't have a way to cut a recess for the router insert, so I feel better buying it ready made rather than trying to make it myself. It will get done sooner and better, I am no metal worker.
And then, there are a whole cast iron top with an insert to match and I could built the cabinet in a day, maybe that is the better way and end up with a better tool...
Thanks again
Jorge
