Question - finishing sapele
Howard In Toronto
I'll be doing my first veneer project this week.
Does sapele need to be filled - as oak does?
Thanks.
Howard
Howard In Toronto
Thanks.
Howard
Re: Question - finishing sapele
del schisler
kind of your choice open grain or closed I have use sapele and i didn't fill It turned out fine for me Just depends on your item What finish you like I used lacquer finish on all my project's Cabnet grade M.L.Campbell Mfd
"Need to be?"
I can't think of any wood that needs to be filled, Howard. It all depends on your intentions and taste. Sapele has big pores, so if you want a piano finish on it, you'll need to fill it somehow.
This begs another discussion, about pore filling and finishing. It is an aesthetic question that affects your finishing decisions. Some aesthetics favor a totally open-pore look, where all the pores are visible and scarcely (or not) filled at all. At the other extreme is the "piano finish", for lack of a better term, where all the grain is filled completely and the finish is contiguous across the entire surface, with no interruptions at all.
In between is where most of us live -- a finish that is partially filled. Most film finishes (lacquers, varnishes, etc.) fill a surface by degrees. The more coats, the more fuzzy the pores become. You can actually fill the pores flush to the surface eventually, by sanding between coats and continuing to add coats until the surface is unbroken by pore indentations.
For this reason, it is important to keep an eye on the micro-level of your finish, to make sure you don't overfill it.
Not much of a prescription here; more like a look around.
Ellis Walentine, Host
need to- no, can be-yes
Bill Tindall
Nothing needs to be filled. Whether a wood is filled or not depends on the look one wants to achieve.
Thank you all
Howard In Toronto
Kind of eases my mind
Howard
Don't Abandon The Mid-Ground
Part of the decision, in my view, depends on the kind of topcoat you'll use. Closed pore woods lend themselves to the higher gloss films, whereas the larger open pore woods like Sapele, Walnut, etc. can get very "busy" when left unfilled and finished with gloss.
When doing an open-pore finish on such woods, I much prefer going to the semi-gloss or even satin ranges for the top coat to hold the light on the surface.
Filling can be done most efficiently with, you guessed it, a pore filler like Crystal-Lac. Before I knew better, I did a walnut piece and filled the pores with polyurethane. Took 2 weeks and some 19 coats of finish, each being cut back, before I got the "piano" finish I was looking for.
Live-n-learn
