Router table substrates
DaleLenz
Need to rebuild my router table's surface, attached to right of TS. Over the last 25 years mine has created a slight hump in the middle, probably because I made the frame (between my Beis" rails) to tight. The router's table surface will be about 2'X3', setting on top of a 1x4 wooden frame. The wooden frame will be bolted to the inside of my Beis' TS rails. Plan on putting two of those threaded inserts to secure my router's base to the table. Any suggestion on substrate material, MDO, MDO, etc.(?).
TIA
. The router (Ryobi 600E) hangs from a 3/8 phenolitic plate that's cut into the top layer with leveling set screws. MDF was edged with 1/2" maple, then over-laminated top and under with mica. Lastly, a miter track was cut into one side with an extruded aluminum track installed for jigs, etc. Dust control is through a plenum box that hangs around the router plus a fence draw port. Stayed dead flat for the last 10 years.
