Very Small Router Collar
Rick Haverstock
Hello All,
I'm on the hunt for a router collar, template guide, rub collar, or whatever else you might want to call it. Looking for 3/16" to 1/4" outside diameter. Smallest standard size I've been able to find is 5/16" OD, which does work, but not too well for my application. Standard PC 690 router base. Tried a Google search, but it's tough as there are too many names for this gizmo. Anyone have a source?? Thanks in advance for your help.
Rick Haverstock
Re: Very Small Router Collar
FredD
If it allows it , you might try sweating a copper tube inside your 5/16ths or 3/8ths template guide and let it hang down enough that it becomes the new and smaller guide.. If it looks feasible , make sure your sleeve is well connected to the inside of the Template guide.
FredD
Dale Lenz
Dale Lenz
Google: router guide bushings, get a boat load of sites, but did not see anything smaller than 5/16". What are you trying to do?
Wade Mackey
You might want to check out Stewart MacDonald. They sell a lot of musical instrument repair and building stuff and have a lot of small router pieces.
Re: Very Small Router Collar *LINK*
del schisler
try this site I have bought from bob and rick
http://us.oak-park.com/catalogue.html?list=BG--&product=G03
Re: Very Small Router Collar - Oak Park
del schisler
will this do It is to early for me to translate the size's I buy lot's of items from rick and bob http://us.oak-park.com/catalogue.html?list=BG--&product=G03
Rick Haverstock
Thanks to all that responded. Fred: not a bad idea to sweat tubing into an existing collar, except for the fact that router bit length won't allow it. Wade: Went to Stew-Mac first. As a guitar and banjo player I already knew that they had some tools for instrument work, unfortunately, template collars were not among those tools. Pecker; Already have the Whiteside inlay set, it has a 5/16" OD collar, nobody else makes anything smaller. Del: The Oak Park site did have a 1/4" OK collar BUT it's only available in a non Porter-Cable size. By the time I buy the collar, a locking nut (P-C ones won't work)and the Oak Park base for my router I'm out close to 50 bucks to gain that 1/16th of an inch. Too many dollars for this guy. Thanks again all.
Rick Haverstock
