OT Gasoline Lawnmower Engine question.
I have one of the older gray John Deere lawnmowers. Its a walk behind. The motor was running but struggling. The gas is fresh Hi test. It started fine but ran a few minutes and then cut off. Sat for a minute or two, started, ran for a few seconds and cut off. I'm guessing it is starved for gas. Is there a fuel filter I could service myself? What else might it be?
Re: OT Gasoline Lawnmower Engine question.
Tom Dunlap
How long has it been since it ran?
If it's the first run of the season and you didn't drain the fuel, run the carb dry and fill with stabilized fuel the carb may be varnished/clogged. This isn't unusual symptoms given the fuel mixes we have these days.
I ran it yesterday with fuel that was probably a month old for about twenty minutes. Put fresh fuel in today. Ran about ten minutes and then cut off.
Tom Dunlap
When I ran my tree care company I would make sure that I used the highest octane fuel for the small engines...and the cheapest for the big ones...
Then, it would never be around for more than two weeks. If so, it would go into one of the truck tanks and I mix new fuel. After talking with saw mechanics they all told me that small engines have become very particular about fresh fuel, mixed or not.
My big saws would be emptied and run dry if I didn't plan on using them for two weeks too. It doesn't take long and the maintenance on them became obsolete after doing this.
The fuel may have 'varnished' the carb. Can you dismantle and clean it? How's the plug?
Ohhhh...look for a ground wire that has broken or frayed. Always start diagnosis with electrical.
Charles in Mtl.
it's telling you to buy a new lawn mower.
Small test to try
Dustmaker Mike
run the motor till it stops then pull the plug if it is to wet then the air is at fault if it is dry then it is fuel or electrical. If air then pull the air cleaner and run the motor does it run longer and better. If fuel then go after the carb. Good Luck
Stuart Johnson
Check the fuel tank cap. I had an old mower and put the gas can on in error. It acted just like you describe. When I changed caps it ran fine. It seem the mower cap was vented. Your mower might need a vented cap and it's clogged.
You might be able to check this by loosening the cap and then starting it. If you do be sure you aren't slopping gasoline around.
Tell us the engine model # and maker
Grant in Iowa
Barry,
John Deere made the mower deck and assembled an engine to it, but they didn't make the engine. Look for an engine makers badge on the engine and post the model # and such and we can help you more.
Sounds like a gummed carbeurator to me. Buy a can of SeaFoam (white can that looks like and old timey oil can) at the auto parts store and read the instructions for small engines. Add what it recommends to the fuel and run it some more. Put the rest in the tank on your car. This is one of the best fuel system cleaners out there, good for injectors and carbeurated engines too. Lots of crazy "uses" listed on the can that sound dubious, but as a fuel additive it is great. More concentrated than other brands, from what I am told.
If that doesn't do the trick, either take the carb apart and clean it with aerosol carb cleaner (different than the above named seafoam), or just get a new carb online if the price is reasonable.
Again, let us know the engine maker and model and we can help more (or you can better search for specific help online).
FWIW,
Grant in Iowa
Tomorrow I will look at the engine.
It's late and I am tired and not wiling to go look at it now.
I think the engine is a Briggs and Stratton but I am not sure.
I did fill the tank right to the top. I will try loosing the cap.
I will also check the air filter. It was very dusty chopping leaves and yard debris. If the filter got as dirty as I did, it will need cleaning.
No brand name on the Engine
I looked at the engine and perused the manual. No name.
5 HP, OHV, Pressurized oil, Electronic ignition.
Pretty much all I know.
More Info.
I was reading the book on the mower and discovered there should be a breather under the fuel cap. A little gadget that looks like a hat turned upside down with a hole in it. There is a slot up through the threads on the cap. Apparently the breather allows air to enter the tank through the slot in the threads but helps prevent gas splashing out and trash getting in.
The breather was not there. Actually, I don't ever recall seeing it, but I don't look under the cap. I never saw it fall out, but my son uses the mower occasionally.
The dealer did not have a breather so I am getting a new cap.
The mower runs better with the cap loose. Not so well with it tight.
Bought the SeaFoam and tried it. Poured some in the tank and some in the Air breather for the Carburetor as suggested on the bottle. Smells suspiciously like kerosene. Did not "see" anything. I sort of expected a puff of smoke. (White for a new Pope, black for we are still working on it.)
And another question
There is a bolt stuck in the deck of the mower. It holds a plastic scoop that funnels the stuff into the bag. The bolt has a head that is either 5/16" or 8mm. (Either fits well.)
The deck of the mower is magnesium. The steel bolt is really stuck. I have soaked it with penetrating lubricant. My 5/16 wrench just snaps past the shoulders and so does my 8mm socket.
Any suggestions?
Jason Roehl in Lafayette, IN
Re: And another question
Someone posted on an automotive forum I visit that a certain magazine did a test of the various penetrants. The best, by quite a bit (based on the torque necessary to turn a rusted then treated bolt) was a 50/50 mixture of acetone and automatic tranny fluid. I'd hit it with some heat, too, before putting on the penetrant, than again after it has set a while and you try to loosen it. WD-40, Rust-Eater and PB Blaster were all a ways down the list. I think Kroil came in second, but took quite a bit more torque than the homebrew.
Jason
Re: More Info.
Stuart Johnson
Drill a small hole in the middle of the cap. This should allow enough air without letting gasoline slop out.
That's a good one to know. I keep a gallon of automatic trans fluid around since that's what Woodmizer recommends for lubricating the rails and things on the sawmill.
Tighten then loosen
Dustmaker Mike
the bolt. Use what ever to soak it then turn it as if you are going to tighten it a little bit more. After that try and loosen it. I used this many times to free stuburn bolts.
Re: More Info.
I had that very thought. I have a number 60 drill bit and gave it some thought. The new cap was $6. So I went with that.
Tony Z
drop the bowl on the carb (usually 1/2 " wrench will dotake some carb cleaner and clean the bowl and jets that are in the bolt that you took out. one side to side the other is tiny at an angle. don't get carb cleaner on the bowl gasket or it will deform. put together and it should run.
Stuck bolts WC-WIKI *patented term*
Grant in Iowa
First off, have a look at your wrench.
On a socket, look for a "six point" socket. This looks like a hexagon when looking at the business end, and not a 12 sided star, or "12 point" socket. The six point is far superior on worn bolts. I have been much more productive and happy since obtaining six point socket sets. I still have 12 point sets, but use them in tight places only. For some DUMB reason, Craftsman seems to sell mostly 12 point sockets in their common tool sets. Must be easier to manufacture or something. I'd love to hear someone explain to my satisfaction why they even make a 12 point socket above about 9/16" or so.
A bolt head rounded off by a 12 point socket may be a lost cause. But there are solutions (see below).
A poor quality wrench will round off bolt heads more easily than a good quality model such as a Craftsman (minimum acceptable grade in my opinion), Craftsman Pro, Mac, Snap-On, S-K, Matco, Husky, etc. Do you need all of your tools to be pro grade? No, but it might make sense to pick up some second hand Mac or Snap-Ons on Ebay in common sizes. Same goes for screwdrivers. The tools I go-to often have all been upgraded to pro grade tools, and working on things is much easier and more enjoyable. As a minimum, your often used tools should be lifetime warranty quality, IMHO.
If a bolt won't come out, first try a penetrating lubricant(which you have done). My mechanic and I like PB Blaster for this purpose. Stinky stuff, but it works good. Next, try an impact driver with a good grade six point socket. Start gently, and increase speed slowly. Let the impacting action break the bolt loose without over torquing the bolt and breaking it off (go easy on the trigger). Try both tightening and loosening in succession, with more emphasis on loosening. Don't have an impact wrench? Next time you need a cordless drill replacement, find a combo kit with an impact driver included and thank me later.
If the above doesn't work, then try heating the area with an acetylene torch. On a stuck bolt, heat the area around it. On a stuck nut, heat the nut. Take obvious precautions to prevent damaging surrounding items, or causing a fire or explosion. This is the go-to method for auto repair shops to remove rusted and stuck bolts and nuts...especially on auto exhaust components.
Try Vise Grips. Good quality ones. Look for the Vise Grip brand, or a lifetime warranty brand.
So if the bolt head is rounded off, there is still a solution. Take a cheap wrench and have it welded to the bolt. If you aren't willing to sacrifice a wrench, then any old bar of steel can be welded to the bolt head. You can even have a larger nut welded to the bolt head. This is a quick and easy solution that will most likely work to remove any bolt...unless you break it off. Suggest heat as above if at all possible. Any auto repair shop worth its salt (NOT lube or tire shop) should be able to weld it for you.
On a bolt that is a "through" bolt on a mower deck or similar, I'd use an angle grinder to simply grind away the offending bolt and install a new one and move on with life.
I also have a related philosophy. It costs me about ten bucks worth of fuel and wear and tear to go to town to the hardware store-not to mention the time and frustration. As such, I decided years ago that it made sense to "stock" an assortment of nuts, bolts, and washers in the shop. I get mine at a local farm supply store that sells good grade bolts and nuts by the pound. For about $50 I obtained a good assortment, which I keep organized in a purpose made organizer (another $20-$30 or so, or build one yourself). If I can replace a bolt with one on hand, I save myself a trip to town. Related, I also "stock" about 100 of each size of commonly used screws, wood screws, cabinet screws, deck screws, etc. I try to use grade 5 bolts, and better grade screws, not the common grade garbage that some home centers sell in bubble packs. It is a one-time expense to create a "bench-stock" of such things, and a pleasure to have on hand for the rest of your life. I have also found that it opens up more solutions when building jigs and shop-use items.
FWIW,
Grant in Iowa
