Re: Staining Damaged Hardwood flooring (OT?)
Al Stokka - Cambridge, Iowa
Barry,
I've used oxalic acid on walnut. Had a table on which houseplants were displayed and water overflowed the pots, seeping under the pots unseen. The result was black (imagine what a black magic marker circle would look like on walnut) rings. Below are the steps I followed with great success:
1. Wood must be free of all coatings, waxes and oils. Use stripper, wood cleaners, sanding or scraping to remove coatings, waxes and oils.
2. Wear rubber gloves, protective clothing and eye protection when using this product. (I do wear eyeglasses, but skipped the rubber gloves demanded on the product label. ;^))
3. Dissolve 12 ounces of oxalic acid (powder) 1 gallon of HOT water. Stir thoroughly until all crystals are completely dissolved.
4. Apply the HOT solution with a scrub brush, green Scotchbrite or old tooothbrush. (I used the Scotchbrite.) On larger jobs use a mop. Apply liberally allowing the solution to remain on the surface until it is bleached to the desired lightness. If the solution cools before the job is finished, reheat but do not allow the solution to boil. Be patient, the acid solution takes a bit of time to remove the stain and may take 2 or 3 applications.
5. Rinse the bleached surface repeatedly with clean water and allow it to dry. I think for the large floor area you have I'd mop it with plain water, dry with a shop vac, repeat, rather than wait for the water to dry by evaporation. Test the removal of bleach from the dried wood by wiping it with a dark colored cloth. Check for powder residue. If powder persists, rinse the surface again with clean water and allow to dry.
6. Sand wood and finish with desired product.
Although product hype says otherwise, I found that the acid mix DID raise the grain slightly. A bit of sanding with fine sandpaper took care of that.
The walnut table was finished with Watco oil and paste wax so that made finish removal easy. Your floor finish will likely be more work to remove. The black marks on this walnut table dissappeared completely, as in, I can no longer tell where they were. I wish I had taken pictures. I think you'll like the results on your floor.
I found the oxalic acid (cheap) at The Chemistry Store (www.thechemistrystore.com).
Al
