Veritas - Innovation in Tools
OT Ford 150
OT Ford 150
OT Ford 150
Stuart Johnson
A hose coming out of the differential was hanging down. When I looked the only place I could see where it might attache was another hose coming under the truck from the front. The loose one fits inside and seems to want to catch on a spring or something after it is inserted about 5 inches. It does not appear to carry fluids of any kind. Any idea what the line is for or if this would be correct. I haven't been ably to find anything online.
I will be taking the truck in for some help with the heater system that looks like it is covered by a service bulletin but would like some idea on what my other problem is before I get to the dealer.
The truck is 2008 Ford 150.
Re: OT Ford 150
Re: Breather line?
Brian in Brighton
I believe it's a breather line/vent.
My F150 4x2 has 231,500 miles and counting.
If I get the next big project that I'm looking at, I'll be getting a 2010 Tundra 4x4.
Brian in Brighton
Re: OT Ford 150
Dale Lenz
According to my...
Dale Lenz
certified Ford Mech. son, Josh, it's a vent hose. Lets rear end oil gases escape caused from the heat built up while driving. If the vent was not there/plugged, it would blow out the rear end seals. The vent hose is attached to the differential to keep water from entering the rear end, verses, just a bare hole in the housing.
Hope this helps
