Help with laying out rectangular to round transiti
Dominic in Buck's County PA
I need to fabricate a rectangular to round transition from sheet metal in order to connect my DC to my cyclone's air filter. The DC outlet is a rectangular flange with a 5 3/4" x 4 3/4" opening. The air filter has a 8" dia opening.
I have been wracking my brains trying to remember how to lay out this transition in sheet metal (in the "flat"). It's been more than 20 years since I had to do this kinda work and I can't remember how. I found a tutorial on line here and here but I'm having a hard time translating what they are telling me into what I can use for this project. Here's a drawing of what I'm looking for.
Normally I'd just draw the completed transition in Solid Edge and then ask the program to project it into the flat. But the old version of SE we're using here doesn't have the ability to convert a part into a sheet metal object. And I have NO idea how to draw this in the sheet metal environment!
Can anyone give me a bit of guidance here? I want to make this out of sheet metal because it will need to handle about 1500-2000cfm @ 8-11 PSIG (rough estimate). Another reason I want to make this to my dimensions it to provide a nice uniform transition from rect. to round.
Any help here?
See ya around,
Dominic
Re: Help with laying out rectangular to round transiti
Re: Help with laying out rectangular to round tran *LINK*
Galen Vetterick
If you are using Microsoft Internet Explorer this site has a small program to make just the transition without your collars. Converts it to a dxf file and seems to show up fine when I open on Autocad 2000.
Gave all my old drafting books away that show how to make the layout by projection. They were 45 years old but hey nothing has changed. Well, except not drawn manually anymore!
Galen
http://www.sheetmetalguy.com/transition.htm
I have you beat
It's been about 34 years since I briefly did sheet metal (and watched a journeyman get canned by my cranky boss because he couldn't do a square-to-round, which motivated me to learn quicklike), and it's really faded.
My only possibly useful recollection is that I remember the bends that made the transition radiating from the corners of the square toward the circle. You've drawn them coming from various points on the sides of the rectangle, but I think they all run to the corner.
Beyond that, you and I both need a working tinbender to remind us.
My memory is that the competent journeyman I worked with laid it out right on the sheet metal. I can't recall the term used then, but it was similar to boatbuilders' lofting, all derived from being able to imagine a solid laid out flat.
Once upon a time, I could do that.
Edit: the old brain cranks a lot more slowly now, but every once in a while it can retrieve things. The term used for that kind of layout was "develop."
That worked PERFECTLY! Thank you so much!
I had just been up in the attic looking for my old Technical Drawing books. I found the section on "Intersections and Developments" and was yawing,...I mean READING my way through it. Now I know why back in 1986 I took to CAD like a duck to water. This hand layout stuff is for the BIRDS
Thanks again
Dominic
Wow, what a great resource. Thanks, Galen.
Alan in Little Washington (NC)
There is complete description of the process and a possible a link to software/spread sheet how to do it on Bill Pentz's site.
Bill Pentz- 5. Transitions
