my recent fine woodworking
Not exactly a work of art, but beautiful to me. I'm extending the end of a 20'x20' outbuilding that has a chicken house on the front and storage on the back. The problem is I'm storing 20' lengths of steel. The building is only 19' inside so I decided to add on a bit.
This construction adds 8' on one end and a 9' wide shed roof all the way down the front for a dry spot for my drum of diesel fuel and some equipment. A little room on the front corner will be to store shovels and pitchforks and chainsaws and such. The interior walls are rough-sawn dawn redwood with eastern cedar on the outside because that's what I have a lot of, mostly 12" wide. I cut rafters and girts from virginia pine and the perlins from pine, sweet gum, and red oak - is this a good use for quartersawn oak or what? It sure is nice to have a sawmill out back.
I'm making use of the rolls of foil-backed plastic that JL gave me a few years ago. Makes a reasonable moisture barrier and helps keep the heat out in the summer.
