What does "latex" mean- latex explained
Bill Tindall
In an earlier post on paint there was a link to a discussion about paint from the perspective of an artist. I thought the discussion of the term "latex" was vague.
In common language "latex' refers to a dispersion of natural rubber in water. But latex has another meaning to a polymer chemist (daughter is a polymer chemist). A "latex" is the product of a manufacturing process called emulsion polymerization. By this definition a "latex" is micron to sub-micron sized balls of polymer suspended in water.
By this definition "latex paint" is a paint made by emulsion polymerization and it has nothing to do with rubber or the other definition of latex. In addition to most water based paint and varnish, both white and yellow glue, and many wax formulations are also latexes by this definition.
They all work in the following way: The water evaporates leaving behind the mushy polymer balls which, if the temperature is high enough, coalesce into a paint, glue, or wax film of tough polymer. Often there is a co-solvent that makes the balls mushy enough to properly coalesce and these solvents are what gives latex paint it smell. The "cure" time for the paint is the time it takes to evaporate these solvents leaving behind a hard durable film.
There are a wide variety of compositions of latexes. The details of the latex polymer composition determines the properties and cost of the material- weatherability, durability, hardness, luster, toughness, etc.
