biesemeyer fence
biesemeyer fence
biesemeyer fence
Lynn Reedy Soddy Daisy Tn.
I have a powermatic contractor series tablesaw that needs a new fence. The fence that came with the saw new has never been extremely accurate. I want to put a new biesemeyer fence on but I need to know if anybody has done that and what problems did they encounter. I appreciate your answers..
Re: biesemeyer fence
I put on on a Rockwell/Delta contractors saw I have had for almost 40 years. My saw had cast grid extension wings. The Biesemeyer Fence slides on the table on the outfeed end. I filled the grids on the table with strips of plywood and covered them with Formica. Bolted them back on and leveled them up with the router table extension I had added. Then I installed the fence. Works great. Love it. Would do it again in a heart beat.
Two points: You must have a level smooth surface for it to slide on and its much better than the old factory fence.
Thanks for your reply..
Reedy
And a Gloat.....
I got mine for $80 when Lowes Discontinued them a couple of years ago. Did not make sense to put a $400 fence on a 40 year old saw I paid $350 for. But at $80 it is pretty sweet.
Re: And a Gloat.....
$80 sounds great... Did you promise to marry the cashier for that price?
Dave Paine
I have not done the retrofit, but my Sears "Hybrid" saw came with a Biesemeyer "Professional" fence.
This is higher than the non-Professional fence, but otherwise the same.
The fence has a large front angle iron which support the rectangular tube against which the fence will lock. This has pre-drilled holes for mounting. So if the holes in the angle to not match the hole in your cast iron sections, then you will need to drill. Bigger issue is if the cast iron sections happen to have a support web right where Bies. has a pre-drilled hole.
The far side also has right angle, though smaller size. Again pre-drilled for mounting and the same issue of holes which may or may not match.
Good luck in your retrofit. I love my Bies. fence. very solid, almost no deflection. I just wish is had a "nudge" feature. The scale is accurate, but can be time consuming to nudge to exactly the desire "just a tad" less or more than the line.
My Bies. fence is laminated plywood for the sides. Mine has slight waves when looking down the fence. Likely common of the brand. The Bies. for the new Delta Unisaw supposedly cleans up the surface AFTER installing.
I managed to get my hands on a new Unisaw at a WW show the other weekend, and looking down the fence it was dead straight. No waves or angle deviations.
The far side of the fence rides on the table top. Their is a nylon or plastic foot, but it will still leave scratch marks over time. Not a big deal for me, but you will need to accept. Other brands may rest on the rear angle.
In the Bies. case the rear angle iron merely supports the table cast iron sections.
FredD
Barry ,
before you filled in the grid, did you ever leave your fingers hanging over the edge of a board or the fence and then slid it along until you dropped a digit into the grid and kept right on sliding ?? ;-))
FredD
Frank
Howdy
I have a Biesemeyer fence on my Delta but I also have a Fox fence on my old sears saw. I would save $100.00 and go Fox fence. It is as good or better.
Frank
FredD
Lynn,
When I bought a PM66 saw, I had the tool supplier retrofit a Biesemeyer fence to a Unisaw I bought in 1974.
The PM66 has their version of that fence and both seem to work just fine.
I did hesitate about the Unisaw fence , becasue I dedicated it to a Rip Saw with a power stock feeder which I thought might move the back end of the fence , but it never has and has been on the saw for about nine years and ripped a lot of hardwood.
So to answer your question is it worth it , I would say so definitely.
FredD
PS One thing I did not like and am years later still cussing is the distance the T-square type fences moved you from your saw's blade during setup.
If your used to the old Unisaw tube rails like I was and you don''t bend any easier then I do , then you know what I mean.
Fred, I did manage to nip a few finger tips on those things. Looking back, I put up with those crappy wings for a long time. (Over thirty years.) They had foru or five ribs running forn to rear and some angled webbing in between. I thoaught they were "Suposed" to be like that, becasue they came that way. Stuff woudl fall through them. other tings woudl drop into them and make an instant stop block. The only use I ever found for them was you could stick a clamp donwn through them and clam somthing to the table.
I glued luan plywood to the webs with epoxy, filling in between the ribs. Ran them throguh my Performax to make the luan exactly match the tops of the ribs and laminated them with Formica. It was a terrific improvement. Seems to be holding up perfectly. My shop is really small and my saw doubles as an assmebly table. There is nothing aobut those grids I miss.
