Best wood for walking stick?
Will
Hello all
To give a brief background, I'm pretty inexperienced with woodwork, having only worked with pine, carving small works with a junior hacksaw, a set of scalpel blades and sandpaper. I have no access to machinery and I don't know what each wood is like to work with, apart from pine and freshly cut conifer. It doesn't stop my enjoyment of crafting and working with the wood.
One of my next projects is to make a walking stick, but I don't want it to have purely decorative purposes. So I come here asking for advice.
What would be the best choices of wood to use for such a task.
Thanks for reading and I look forward to sticking around and picking up tips
Re: Best wood for walking stick?
Carol Reed
Mine is diamond willow. It is a traditional wood for a walking stick. Click on Woodfinder to find a supplier.
Terminology question - are we talking about a cane (short, 3' or so tall) or a longer walking stick - 5' or more?
I've made some longer ones out of white oak and hickory that I've been quite pleased with. You can get rubber tips or metal tips for the ends.
Clint Searl
Clint Searl
American Hornbeam and American Beech are super, as the bark tightly adheres and is very smooth. Hop Hornbeam has a beautiful color and texture if the bark is removed. Dogwood is quite nice, also. All four are tough and durable.
Clint
John McGaw
Given the proximity to St. Patrick's Day and my semi-Irish ancestry I'd have to say that the proper wood for a walking stick is blackthorn (Prunus Spinosa).
John Veerkamp, Western Mo
for a walking stick(longer than a cane) almost any wood will work. What you want to look for is relatively straight, comfortable fit for the hand, and without structural weakness. I've made them from old Christmas trees (spruce) walnut, oak, locust and hickory. My all time favorite is osage orange 66" long, about 1 1/4 dia for the hand and about 1" every where else. I wrapped the base with galvanized 12 gauge wire to prevent splitting, finished with Linseed oil. It is heavy for some but just right to swing while walking thru the woods.
Terry in Edmonton
Diamond willow and Lilac are the woods of choice up here. Both are common and very hard and durable. I still have my grandfathers cane made from Lilac that is in top condition after 60+ years. My gradfather used it, my father used it and when my back went out I used it. It has outlasted many rubber tips in its life.
Do you have dogwood trees in the woods nearby? When not out in the sun they grow tall and thin. The wood of a small one makes an excellent walking stick just by peeling off the bark. Around here you can often find one with a spiral growth where it was choked by a honeysuckle vine that makes a very interesting stick.
Blue
You mentioned Pine, I like to cut a 3' or so length of it, drill a hole in the center, find a handle for it in the woods, Oak, Hickory, Dogwood, etc, and put it in the Pine after it drys a few months. You can find great handles in the woods.
Re:My favorite
Dale Stansbery
I made one from a Dawn Redwood branch years ago that I like a lot.The bark is tight, smooth, and just enough texture for a good grip. The old leaf scars also give it a neat pattern (little white specks), oval in cross section, and tapers little over 5.5 feet. This wood takes great detail when carved, and in branch form is light and strong. The drying crack is from making it green instead of waiting for it to dry, then trimming it off..
I would have posted earlier, but I have been tangled up in passwords, now solved.
Thanks all
Will
There has certainly been some useful ideas. There is a chance that I'll be able to get some access to some willow after the weekend. At present, I'm in the process of sanding one of my 3 pine sticks. I've sawn and stripped the bark off another to make it into a small cane and I might go off and find a larger piece of wood to make into a handle, and I've left the last one to dry with the bark on.
By the way, that's a pretty nice pattern carved in there
Mark_in_Michigan
I have used Walnut and White Oak with success, the White Oak is a bit stiffer. I got the rubber/metal cane tips from Lee Valley as mentioned above. I even laminated one out of Walnut & White Oak and then milled it on my Legacy Mill, came out very interesting with the different color woods. I have even had some non-woodworkers ask how I carved it so well that when they were glued together it came out perfect.
Re: Thanks all
Roy C. Gryder
Will, I don't know where you are located but here in western NC we go to the woods and look for a rhododendron with a pleasing curve that makes a handle. The wood drys hard and strong. The wood color is a creamy white if you wish to carve a pattern in it. R.
rhododendron
Hey, if rhododendron is thick in your area I'll trade you something for some big roots! (need any walnut, cherry boards?) Years ago a guy gave me some roots for woodturning and they had the most fascinating figure.
Re: My location
Will
I'm actually in the UK. I probably should have pointed that out in my opening post
