Power deck on home made drum sander
Wayne Carson
am building a drum sander and am having trouble with the power deck. I for the life of me cannot get it to track. It keeps wanting to go to the right side. There is an adjustment so I can get it to track but it won't. If I adjust the right side to much it really loads the motor down, when I tighten the right side and loosen the left the left side just hangs. The rollers are 1 1/2" sch 40 PVC with a 5/8" shaft full length. The other roller is the same, both sides are adjustable.
Any help would be appreciated.
Wayne
Re: Power deck on home made drum sander
Alan in Little Washington (NC)
What kind of conveyor belt are you using? Sanding belt type or rubber-over-fabric conveyor? Did you make it yourself?
Three things can cause your problem- the rollers are out of parallel, conveyor not round, or conveyor stretched (not round also).
Your roller position adjustment is likely very sensitive- are you adjusting it in very small increments and letting it run for awhile to see how it tracks and to see if it starts to drift back to the correct position, or are you expecting it to track correctly right away? - it won't unless you have over corrected! At the speeds these things typically run it will correct very slowly, and as it reaches the correct position you need to take out some of the correction.
It doesn't matter if the rollers are perfectly parallel (equi-distant) if the belt is not perfectly round- the circumference is EXACTLY the same on the left and right edges. I suspect that may be your problem. You will never be able to get an out-of-round conveyor to track correctly.
FredD
Don't feel bad Wayne , I have a Delta 1836 drum sander whose conveyor belt needs adjusting constantly, it seems to be the nature of that particular beast.
FredD
Galen Vetterick
I assume the PCV pipe rollers are concentric with the inner shaft on both rollers? If you used wood disc spacers to connect the inner shaft to the PVC did you true up the final assembly so the outer drum runs true with the shaft?
Are the rollers rigid and not flexing?
With both rollers adjustable it will be very touchy trying to track.
Can you square the shafts to the sides of the belt?
Can you measure from one end of the roller to the oposite end of the other to make sure the diagonals are equal that should square the rollers to the belt.
Otherwise you will form a parallelogram (the end of the rollers will be the same center to center but not perpenducular to the belt edges). The other way you get a trapezoid with the rollers not parallel or perpendicular to the shafts.
Like noted by others could the belt not be the same circumference at both edges?
Should the rollers have a crown if the belt stretches in the center from use?
Just random thoughts this late.
Galen
Rick L
Rick L
Sounds like you don't have a crown on your rollers. This is a must to track the belt properly. It may sound silly but this a standard thing or your belt will never track properly. I've done a quick fix by wrapping tape around drums to make a taper. Black tape will work fine or even masking tape. Black tspe lasts longer and duct tape is too thick. A slight crown of 1/32" might be enough. The tape is nice because you can tweak it gradually. Look at any belt sander, conveyor to see what I mean. If someone says bad tracking is common then they don't know about the crown...
Rick L
Re: Conveyor rollers must be crowned!
Rick L
Wayne Carson
do you taper the crown
Conver
Wayne Carson
Conver is 100 grit sanding belt custom made for me by manufacturer it is round first thing I checked when itwouldn't track.
Rick L
Re: Taper the crown...
Rick L
I'm not sure how you can picture a crown without the taper. All conveyor rollers on sanders have slight crowned tapers to track properly. Also belt sanders. I've tweaked many a belt sander with the tape trick. Take black electrical tape and wrap it around the drum in a spiral starting about several inches from one end and stop it several inches from the other end. Then start another cource a few inches from where you last started and end the same way. The tape allows you to adjust and re-adjust the crown. 1/32" high spot in the middle should be fine.
Woodie49
I would like to see Pic. of your sander
With Sched 40 rollers, you have enough thickness to use lathe tools to turn a slight crown.
Remember bandsaw tires are crowned also.
how do I post photos nowdays
Wayne Carson
since everything was changed I can't figure out how to post a pic and what size to post!!!
Drum sander PICKS
Wayne Carson
Re: Drum sander PICKS
Woodie49
Do you have plans?
In my head
Wayne Carson
Re: In my head
Woodie49
Do you ever think abouth making drawings?
Re: In my head
Wayne Carson
if anyone was interested I could make a drawing.
Rick L
Re: Why is this so difficult...
Rick L
Yes he could turn a taper on the sch 40 roller. The idea of the tape is to try and figure out the amount of taper to prove to himself that's what the problem is. It's reversible and adjustable.
Rick L
Re: Conveyor problem solving
Rick L
1 Since you said it always pulls to the right, can you verify the belt isn't tapered?
2 Do you know for sure your conveyor rollers are true? Could they be out of round or not centered on the shaft?
3 Try putting a bit of tape on the center of the drum to simulate a crown.
Thinking more about the belt pulling to the right it sounds more like a belt issue. If it wasn't so wide I'd be inclined to turn it inside out and if the belt is at fault it should pull to the left after being turned inside out.
Beats the ____ out of me
Wayne Carson
This is the only thing that I thaught wouldn't be hard. I originally had the sides made of 1x3 red oak and the belt tracked very slightly to the right but wasn't adjustable so in my wisdom I made the sides a little longer and put some adjustment in the rails and it has been nothing but a pain in the rear ever sence. I have checked the belt by measuring each side and as beat I can measure they are the same. I did get the turkey to go to the left once but haven't been able to duplicate the feat since. It rally shouldn't be that hard! I figured I could take any adjustment out with the adjusters not going to happen at the moment. I am just about to the point of using a hand crank but I don't want it to win I have a few more years I hope to work on the problem. But it really works nice until the belt hits the sides.
I know it looks kind of like a "Rube Goldburg" project but there are lots of clamps to make it easy to take apart at the moment. When I get it working I will put a set of drawing up for anyone interested in building. I'll put a pick of it with the sander and cover tonight or tomorrow. But tonight it is back to the tracking problem. I have put tape on the roller but looks like I need a little more.
Taper worked
Wayne Carson
That is what it needed after a load of electrical tape it worked just fine vary little tweeking to get it to track.
Next time I start to do something let me know before I spend a week or two inventing the wheel.
Thanks again Rick
