We value your privacy.
I have to make an angled/beveled shoulder onto the tenon'd stretchers I am making for a coffee table. This is to account for the tapered legs, they are mortised into.
I am thinking of making four seperate passes through the table saw (using miter gauge, and dado blade). However this means four seperate blade settings. Is there an easier way, or will this prove to be easier than i presently envision.
It sounds like the rails are not at a right angle to the leg, is that right?
I've done what you describe using a tennon jig when making chairs. Its very straight forward once you have the method for measuring and setting the angle, and I don't recall even that being too difficult. The one thing I had trouble with was organizing the cut so that the drop piece didn't get caught by the blade and thrown violently back at the operator. First one did that
Absent a tennoning jig, I think I'd make the shoulder cut on the table saw and then cut the cheeks on the bandsaw. I often do this when making large tennons for doors, but I usually cut the tennon a bit oversize and use a large shoulder plane to fit it exactly. On one occaission I had a really good bandsaw blade and the cut was nice enough to skip the planing. You'd think I'd buy better blades after that
If you have a bandsaw blade butt welder you can weld your own blades. It takes a little practice, but you can cut the blade prior to welding so there are no missplaced teeth at the weld. The weld can be ground and the teeth next to the weld filed so there is no missmatch of teeth, hence, a nice smooth accurate sawcut.
But I'm missing some parts and haven't gotten around to making replacements yet. I tried ordering them from Do-All a couple years ago, but nothing came of it. Free blade welder = extra work
I've also silver soldered blades, its fairly easy to do, though the joint often breaks before I've really exhausted the blade. Cuts were fairly rough, but that was likely the blade stock I was using, it was nothing special.
I did buy a couple of Highland's blades last year - I was out of acetylene and couldn't solder up a new one - and I was very impresses with their run of the mill 1/2" blade. Even when I get back to making my own I expect I'll keep a couple of theirs around too.
After googl'n Do-all awhile back, it appeared that they are no longer in the business of bandsaws. Unfortunate because, they made one of the best metal cutting bandsaws around, back in the 60,s and 70,s and up to whenever they stopped making them. I now own a Jet brand that is pretty much a squared off pile of junk in comparison. The welder that came built in, does a pretty good job but I had to make a blade cutter that would cut the blade square at both ends so the two ends would completely be in contact before the weld begins. With the squared ends, the welder does a good job. The welder has come in handy a few times when I needed to cut an inside shape without cutting through. Drill a hole, cut the blade, feed it through the hole and weld it together again, make the cut, then cut the blade again, then weld it back together again. Seems like a lot of mess'n around, but sometimes it saves the day. And I hate jig saws, but they have their place.
Regarding cutting tenons, a well sharpened small tooth regular panel rip saw can cut a tenon very accurately when you don't want to take out a loan to buy a good present day tenon backsaw. Most older saws are taper ground and can be filed with very little set just like backsaws are set when done properly.
Upon further review of my dilemma, I have decided to "cheat" as well. I think the strength of this joint will be diminished by the improper angle of my shoulder and cheek cuts. So I have decided to simply cut the end flush (at proper angle), and use a dowel joint. Maybe I should attempt a 'floating' tenon. Is the square peg vs: the dowel a signicant improvement in strength?
The joint is for the bottom shelf supports on a coffee table, and besides the occassional foot on it, should not see a lot of stress.
Well, this opens a can of worms and we may start a row but, I really really hate dowels. A square peg would be better because you get long grain on all four sides, while a dowel is part long grain, part end grain for most of the circumference. Plus, see the discussion in another thread about the difficulty of finding a well fitting dowel.
Floating tenons are easy. The only trick is to route the mortise at the correct angle. I cut the pieces to the proper angle, then fit the mortise at 90 degrees to each face.
A simple jig for this is to cut two boards the same size, nice and square on all four sides and draw the piece with the face to be mortised flush with the right side an inch or so from the bottom of one. The bottom of the workpiece will be angled to the bottom of the board. Now cut a board the width of your workpiece with the angle on it and glue & screw to the marked board. Glue and screw the other board to the other side of the angled piece, keeping it parallel to the marked board. You now have a jig that will hold your workpiece at the proper angle so you can run a router on the angled face and cut a mortise 90 degrees to that face.
Harder to explain than to do. If this doesn't make sense, I can send a picture.
This may not be a hugely popular suggestion on this part of Woodcentral, but if you have to draw out the layout lines anyway, sawing the tenons by hand would be trivial compared to figuring out a table saw setup.
I've used Tage Frid's mortise very simple jig for that purpose. It's described in his book, and here: http://www.highlandwoodworking.com/tagefridsmortisingjig.aspx
To use it for cutting mortises in the ends of workpieces, just make sure there's room for the piece to stick up through the bottom of the jig. A mortise in a simply beveled end can be done easily by attaching stopblocks to accurately position workpieces. A compound bevel requires a wedge-shaped spacer, and stopblocks.
