How much to allow for expansion
jared
Hello I am building a table for my daughter. I have a solid oak glued up panel, 3/4 in thick by 16 inches wide. How much expansion in width can I expect. It is now the dead of winter here in Iowa, the oak is kiln dried and humidity is low. In 3 months it will be warm and very high humidity. Will the 16 inch width turn in to 16 1/4 inches? I had planned on allowing the 1/4 in, will that be enough? Thanks in advance. Jared
Re: How much to allow for expansion
Dale Lenz
ASSUMING
Dale Lenz
Your oak is 6% and the boards are flat sawn, tangential, would expect 0.4" from 6% to 12%, slightly more than 3/8".
Re: ASSUMING
jared
Thanks I thought of it after I put up the post, the boards are flat sawn. Jared
