How to frame a picture in hardwood?
Anyone have experience in making picture frames out of hardwood such as oak? I'm making a bunch from old oak barn wood, hard as steel (almost)! The wood is probably 60-100 years old. I have a good frame clamp. When I last made similar frames many years ago I glued the miters with yellow glue then drilled holes from the side and inserted finishing nails. They have held up fine.
One article recommended reinforcing the joints by drilling a large-diameter shallow hole in the back (across the miter) and gluing in a plug.
I've never used v-nails. I've read they may not work so well in hard wood.
So questions:
- What type of glue is best for the miters?
- What are some proven/favorite ways to reinforce the joints?
Re: How to frame a picture in hardwood?
Here's John's message again
>[We're still trying to find the reason why the above message didn't display. Never a dull moment.]
So questions:
Feathers
Good topic, John. My favorite method is to glue one or two 1/8" thick feathers into each corner. The routine is to glue the frame first without any reinforcements, then cut a kerf in each corner by standing the frame up in a special push block that holds the corner at 45� to the tablesaw. Plane a strip of the same or contrasting hardwood to the width of the kerf, cut oversize triangular slices out of it, and glue them in. Clean up with a block plane, pushing from the corner so you don't tear out the short grain at the tip.
Second the feathers
John in NM
Super easy, nice and strong, and they really look great.
I did some once on a jewelry box for my wife that were built up of contrasting veneer.
Re: Feathers
John Veerkamp, Western Mo
some texts call these splines. Using more than one on each joint in contrasting woods can really give a touch of unexpected refinement in a " rustic" frame.
Re: Here's John's message again
NickTuzzolino
John, Your are right about the V nails in real hard wood (unless done with a professional machine), forget about it. All of the above referring to feathers or splines are great suggestions. I often use them for larger frames.
I often use a biscuit and bit system sold by Woodhaven, about a dime sized biscuit with a special bit. This is for smaller frames.
Dale Lenz
Here's what I did many moons ago....
Dale Lenz
long ago before Internet, big screen TV and cell phones. Put blind spline, or keys. The reason for the blind part was I trimmed the barn wood with walnut on the inside and outside of the frame to hide the fresh cut barn wood. The walnut trim was higher than the barn wood a fraction of an inch, was a big hit to all that seen it. Another reason for the blind spline at least in my mind I wanted a "clean" corner. If I continued with these frame I'm sure I'd tried some "showey" wood splines, keys or feathers.
Enjoy and have fun.
Blind spline
I'll have to think if I can do a blind spline. I had considered a spline (a strong joint) but dismissed it because I didn't think it would look right on these frames. I make barnwood frames a bit unusually, perhaps. I only use the edges of the wood - rip about an inch or so which gives me a 1" square cross-section, and cut the rabbit and turn the wood such that the all three faces showing are weathered (with the freshly cut face towards the wall). This makes a thin frame but looks great. I figured the smoothly cut spline ends would not look right against the deeply weathered wood.
A tiny biscuit would work great. Maybe I can cut a blind slot with the router and make some little biscuit-shaped splines.
This project is for a set of family portraits for a friend's mother/grandmother who is driving up for a visit in a couple of weeks. It's fun to be able to do the whole thing - take and print the photos, make the frames, and cut the mats.
I have a bunch of weathered wood I ripped off the old barn if anyone local wants to make a few frames.
And thanks, Ellis, for reposting. I couldn't figure out why my message shows up in the index but disappears when I click on it!
Dale Lenz
Re: Blind spline
Dale Lenz
I'd guess I used a router with a 1/4" end mill bit as that was what I had back then. That's a good idea of using the barn wood's edge as the picture frame 'face'. I actually used some 3/4" weathered hard maple from a table top that I found in a private dump, I wanted the table's leaf expansion hardware under the table top.
FredD
I used Yellow glue and sometimes splines for years until they developed Cyanocrylate glue in Gel form.
For small frames under three feet square , it is the fastest and easiest of all methods I have tried and no clamping.
Depending on the frame stock profile , I sometimes use a pin nailer to speed up the assembly,along with the glue.
I use a accelerator with it and I haven't had a joint failure yet.
FredD
Does not sound exactly like what you are doing, but years ago I made about a hundred barnwood frames for a restaurant chain. I started with a weathered board about 6" wide. (Pine in my case). Ripped a 3"=/- piece off one edged and and 1 1/2" off the other. On the wider piece I rabbeted the weathered edge to receive the glass and picture. Rabetted the smaller strip to wrap around the frame and create some depth. The flat inner pieces of the frame were butted, except the ends had matching rabbets forming a sort of shallow half lap. The back band pieces were mitered. All the exposed wood was weathered.
Side Note. You can buy weathered wood locally from some lumberyards. They make a lot of movies locally and the set builders are looking for "characteristic wood" for barn and fence parts.
