Re: refreshing Melamine cabinets - Paging Jason Ro
Jason Roehl in Lafayette, IN
Sorry I took so long to get back to you, Carol--I saw your post this morning, but didn't have time to type out a reply. I had to take my boys to their first of several Hunter's Education classes put on by the Indiana DNR so that the boys can participate in the 4-H Shooting Sports.
Anyway, yes, melamine can be successfully painted. The question is what the definition of successful is. All paint fails eventually, then you have even more work on your hands to renew it.
What it would take is significant abrasion of the melamine surface (probably in the 120-150 grit range), a good bonding primer, then at least two coats of a good enamel. I lean towards waterborne products. In this case where you're talking about the cabinet carcasses, and solvent-based product will off-gas for some time to come, meaning you either have to let them air out for a month or more, or put up with smelly dishes.
That said, it would be quite a bit of work to paint the carcasses, even if you have access to spray equipment. By hand, it's probably even more, but you have a little more flexibility in terms of being able to work on them for an hour or two here or there. With spraying, you want to do it in as contiguous a manner as you can.
I would recommend NOT painting them if you can avoid it. Melamine is pretty durable, so you should be able to get pretty aggressive with your cleaning. 409, Simple Green, vinegar/water, baking soda/water, any or all of the usual suspects would be in your arsenal here. It just depends on what you are trying to clean off (and this is starting to get outside the scope of my expertise...
I don't do much cleaning).
I hope this helps and have fun!
Jason
