Disassembly of cured yellow glue joints
Bill Tindall
At our last club meeting Buddy Floyd, furniture restorer and master cabinet maker, described furniture repair and restoration. Among the many tips was one on how to disassemble joints. The myth goes that one should not use yellow glue in furniture as it can not be disassembled like hide glue. Not true.
To disassemble a yellow glue mortise and tenon joint it is first drilled most of the way through, about in its center. For a source of steam I used a pressure cooker, a short length of hose and a basket ball inflation needed, as recommended by Buddy. The needle is stuck loosely into the hole and steam applied. After about 6 min I tapped the joint with a mallet and it came apart cleanly. Frankly, I was astonished at
how easily it worked.
