movement in arbor
movement in arbor
movement in arbor
Kevin
I have a Jet cabinet saw. The arbor moves side to side about .003 to .005". I pulled off the belts to get that measurment and to feel the play. I'm going to loosen the arbor pulley set screws and try to tighten the pulley side arbor nut (see diagram).
http://tinypic.com/m/8yxa2x/3
But this seems more and more like the bearings have side to side play.
I see on this website a procedure for replacing the unisaw bearings. The arbor design appears to be nearly identical to my Jet.
Can I do this all under the table? How do I drive out the the arbor without damaging it?
Re: movement in arbor
Rick L
Rick L
Take off the table to get at the assembley. I seriously doubt it's bearings. Perhaps you are missing the spring washer? You don't need special tool to remove the arbor. A screw driver to remove the special nut unless it's just loose in the first place. A dowel and hammer will easily remove the arbor. It's possible to do it without removing the table but it's a lot harder with the table on to see what's going on. An hour of work.
BTW...Spent many years as a tech for a dealer and used to do a lot of unisaw bearing changes.
Kevin
I'd prefer to try without removing the table - I have it and the right-side table all nicely aligned and near dead flat. I'm pretty familiar with the underside. This is a pretty new saw, I bought it used, but it was in great shape, so all of this surprises me as well. But there is clearly some side to side movement, and maybe even a bit of up and down movement on that arbor.
FredD
Kevin ,
try this for the right information
http://jettools.com/us/manufacturing/en/service_support.html
FredD.
Rick L
Re:Right info???
Rick L
The Jet is an exact copy of the Unisaw. You can do it from underneath but it will take just as long as removing the top in my opinion and experience.
Re:Right info???
FredD
Rick ,
I was not referring to you or any other specific post about possible causes of slop in a Saw Arbor , what I did do and highly recommend is that you should be able to get a quicker more accurate answer about a problem with a tool from it's manufacturer.
If you will notice , many questions have many differing answers posted and if your unknowledgeable about the subject in question, save yourself time and effort spent sorting possibles by going to the manufacture who undoubtedly has already had the question asked many times and has the fix at hand.
FredD
Re:Right info???
Galen Vetterick
I agree with Fred. Find out from Jet what the side play tolerance range is and if they have a suggested way to adjust before the bearings need replacing.
Then find out procedure to replace if needed.
I have always gotten answers from them when ask.
Re:Right info???
Kevin
I took off the pulley-side arbor nut, loosened the pulley set screws, and with a block of wood drove out the arbor from the bearings. The blade-side bearing came out with the arbor. I looked it over, and it seemed like the blade-side bearing might be a bit loose-- but very small amount. I was going to get a new set of bearings and just replace them. But since I couldn't find a local store with bearings today, I took a look at what it was going to take to get that other bearing out. With the top on, it was going to be a real bear to loosen that spanner nut (then tap out the bearnig with a larger block of wood. (And then I'd have to figure out a way to pull the other bearing off nearly the full length of the bearing -- and get the new one back on!) So I thought I'd just put it all back together as a practice run to see how hard it was going to be to put back what I had taken apart. I needed my son to hold the pulley and one spacer in-place, but we mananged to get it back together. With a block of wood on the blade-side arbor, using a hammer we tapped it mostly into place, and then using the arbor nut we snugged it all together tight. Then I backed off the arbor nut about 1/4 turn. It seems like it might be just a bit stiffer on the rotation than it was before, but it does spin freely and surprise, surprise -- all the play is gone! My guess is that maybe all the inner runs -- arbor, arbor spacer, pulley, arbor spacer, and arbor nut were not tight to begin with. When I spin it up, it sounds fine. I does concern me a bit that I had to put quite a bit of leverage on the arbor nut when I tighten it up -- to fully draw in the blade-side bearing -- and that it seems to spin maybe just a bit less freely. But time will tell I guess, and for now, it's solid like I would expect it to be.
Re:Right info???
Kevin
RE: calling Jet, I did that twice -- mostly to ask about the arbor assembly in general, but they asked why I wanted to know this and I told them that I had 3 to 5 thous. of play and they just sort of dismissed it. Well - I can say that in that arbor assembly there should be no side to side play at all -- at least that is measurable by my dial indicator. If I can measure 5 thous. and I can "feel" it moving, that's not right. I had a Delta contractors saw -- older one, made in USA, and there was no play. We'll see if my take-apart/put-it-back fix lasts.
