Scroll Sawing Can Be Dreadful
George Colonel's Workshop-Havertown PA
Good Evening Friends,
I've owned a scroll saw but never seriously used it. Now I have to make sets of chess men, 32 men per board, six boards. The chess pieces vary from 2 1/4" to 3 1/2". I am using poplar blanks, 1 1/2 inches square, and applying the templates to adjacent sides with spray adhesive. I am drilling holes in the bottoms of each piece for lead shot as weights. I am also drilling relief holes at transition points, about 20 per blank. I have the first 32 pieces fabricated. I bet I broke 20 blades so far. The blades are 18.5 tpi/pin type. I find the speed of approx 1400~1500 opm to be fast enough for smooth cutting, despite some mental lulling. Then a blade breaks with a loud bang and wakes me up. I bought the blades at Orange Borg ( Ryobi) and some at a local hardware store ( Olsen). I wonder if that degree blade breakage is a "cost of doing business", or a cost of learning to like a scroll saw. I feel like blowing it up when the projects are over.
I need some advice on blade sources, pin and pinless blades themselves, tension, feed rate, and a good place to recycle the broken items. At the rate I am breaking them, I'll have a hundred pounds of broken blades before I'm done. I'll be glad to see this phase of the project over.
George
