Simple Green
Grant in Iowa
Available at home centers, simple green can be purchsed in gallon jugs. In addition to being my favorite for cleaning saw blades of pitch, it is a great cleaner.
As far as use in a pressure washer, here's the blurb from the Simple Green website:(Begin cut and paste)
Can Simple Green be used in a Pressure Washer / Power Washer?
Simple Green does a great job when used in or with a pressure/power washer.
It can be used to clean vehicles, concrete, siding, lawn furniture, canvas, etc.
For cleaning siding (aluminum or vinyl) use approximately a 30:1 dilution. (30 parts water to 1 part Simple Green.) If you have to pre-mix in a bucket and then your equipment pulls it straight through, mix 4 ounces Simple Green for every 1 gallon of water. If your equipment automatically gives you a dilution and you can't alter that dilution, it is probably a 7:1 dilution (most common.) In that case, mix a 4:1 dilution in a bucket and pull that through. (4:1 @ 7:1 = a 28:1 solution.) Start at the bottom and work upward to avoid clean streaks. Work in sections, cleaning and rinsing, so that the product does not dry on the surface before the rinse stage. Really heavily soiled siding might require light scrubbing with a non-metallic bristle brush or shop broom.
Before doing this job, make sure you have eye protection. Simple Green will sting your eyes but not damage them. However, the pollutants and oxidized paint that can come off of your siding can seriously damage your eyes - so please wear safety glasses or goggles. Additionally, move any vehicles, people or animals away from the downwind area of your job. (Vehicles won't be harmed, but wax might be removed if over-spray sits on the car for too long prior to rinsing.)
After the job is over, give any ground areas exposed a good watering. This will help the Simple Green and water penetrate the soil, where it will biodegrade. Rinse off plant leaves and tree-trunks. Don't leave any standing puddles or containers of Simple Green and water where animals might drink. Too much ingested can cause diarrhea.
Lastly, when cleaning vehicles, lawn furniture or canvas (same dilution ratio as siding,) don't allow runoff to enter storm drains. This is a violation of the Clean Water Act (which states that nothing can be put down a storm drain but rainwater!). Simply push the runoff with your hose or pressure washer to a grassy area and water it in.
"""End of cut and paste
Remember that the gallon jug is a concentrate. I think a gallon is about $10, maybe less if it is on sale.
In my experience, I have used a pressure washer to clean car engines (be careful around newer engines, as the soap and water can mess up sensors).
What I do is take a disposable or old paint brush and paint on liquid laundry soap on the greasy parts... scrub a bit with the paint brush and let it sit a while. Then pressure wash the area clean... even works good with a plain old garden hose. I used to keep my car engines clean enough to eat off of back when I thought such things mattered and had lots of time on my hands.
Regards,
Grant in Iowa
