Anyone know what happened to Turbinaire HVLP???
Mark Lepore
A
Re: Anyone know what happened to Turbinaire HVLP???
Re: Anyone know what happened to Turbinaire HVLP??  *LINK*
http://www.turbinaire.com/
Mark Lepore
I found that site, but the phone number is no good. I hope they are not out of business..... my gun is acting up. If they are, hopefully someone took them over.
S'mattawhitchaGun?
Spray guns are very simple things.
It's doing (or not doing) what?
Re: S'mattawhitchaGun?
Mark Lepore
You are so right. The gun is a no brainer. That is why I am so frustruated. I have had it apart several times, rebuilt it with no o rings and seals, replaced the filters to the power unit and it still sputters.
It will work well for about 45 seconds and then gradually the amount of product will decrease until nothing is coming out. Now here is the weird thing. If i still have the power unit running, disconnect the pot from the gun and hook it back together, it will work well for another 45 seconds.
I know there must be a super secret spot that is clogged that I missed when I cleaned it, but I will be darned if I can find it.
Got any great ideas?????????????
Have a good one,
Mark
Phil Joines
Sounds like it's trying to pull a vacuum. Is there a vent hole that's clogged?
Vacuum
Assuming that your gun is a siphon rather than a pressure feed, you need to find and clean the tiny port [usually in the gun lid] that vents the pot. Sounds like a block of dried finish. You want to examine exterior and interior of the lid.
Now, that said, I know that some turbine systems use a pressure feed that bleeds off the inlet at or close to the air inlet. This is required when applying heavier bodied finishes. They normally use some flex tube and a couple of fittings, either plastic or brass, and may incorporate a check valve to prevent blow-back of liquid into the main air line. You'll need to take them apart and carefully clean the entire line. Won't take much to screw up a check valve.
Mark Lepore
That was my thought exactly as at times I can hear it bubbling inside. It is just a matter of finding where the clog is. I have had that thing apart several times. My buddy who wanted to use it took it apart also and he too had no luck - a mystery at it's finest!!!!
Re: Your Gun?
Mark,
Turbinaire's site is still working and I checked to find parts and stuff. What's the model No. on your gun? Does it have a pressure feed from the handle to the cup?
