Any shortcuts to fixing sand through
Dale Lenz
Dale Lenz
on a high sheen finish? This is a problem for me, sanding through on lacquer finish, 8-9 coats, cured for several days or longer. Seems maybe 50% of the time I'm sanding through someplace! My fix is to lay some more lacquer down, let cure for several more days and attempt to resand, often sanding through someplace around the area. My question is there a shortcut, like those shellac sticks? Remember this is high sheen. Can get by by dapping a few layers of shellac on a satin lacquer finish sand through, wait a day and hit the area with sandpaper, 400-600 grit, then maybe wool or Scotch-bite type pads.
TIA
Re: Any shortcuts to fixing sand through
an ounce of prevention.....
Bill Tindall
8-9 coats of finish, days to cure?! That is extreme to the max. I don't have this problem with my typical three coats which I rub out the next day.
You need to find, and fix, the fundamental problem. Either you aren't really building 8 typical coating thicknesses (which would be something like 0.024-0.050" thick for 8 coats), the coating you are building is atypically rough such that it needs excessive sanding, or you are over sanding.
A leveling after coat #1 takes care of roughness induced by the wood fibers and dust. After that each coat should lay down at near glass smoothness if the viscosity of the finish and its solvent package are right.
Re: an ounce of prevention.....
del schisler
what kind of lacquer are you using From the box stores ? That is not the best but maybe the cheepest The quality is not their I use m.l.campbel lacquer and i don't have to sand only once I use sanding sealer and sand the ruffmess out and than 2 coat's and i am done The finish is fine for me More than 3 coat's and you will find that it will crack on you ? I have tested and find that 4 coats and it will crack also Maybe not with in a week or so a couple mo. and you will see it I make jewelery box's like maybe so far couple hundred I sell at a craft shows
Dale Lenz
Okay....
Dale Lenz
admit, my spraying techniques maybe need some improving, but until that happens are there any short-cuts to repairing a sand through on a high sheen finish.
Short Cuts
to a perfect finish are few and far between. In your situation I anticipate that you'll need to mask off the surface with the damage (i.e. the entire top, etc.) and redo that section. Unfortunately this means removing most, but not all, of the existing lacquer on that surface. Leaving a very thin coat remaining will act like sanding sealer. Then recoat your burn-through(s), level, and proceed as if top coating. Trying to do a spot repair in a high gloss finish will show up by differences in either texture or color or both.
FredD
If your practiced at spraying and your equipment is working properly , you should be able to lay down a sanding sealer , level that with 220 garnet, shoot no more then three or four coats of Lacquer and go straight to rub out with something like Mequiars Auto finish compounds or wet or dry sand paper with soapy water .
FredD
Some thoughts for preventing sand-through
Ed Mulligan, Cape Cod
Finish near an edge is thinner. Stay away from sanding near edges.
Count strokes and try to give each area the same sanding effort.
Change sandpaper frequently, especially if it is clogging.
