Just a couple additional notes
Scott in Montana
I think Barry has done a good job of answering your questions. The one thing I'd like to clarify is that I bought this sliding table because is was much more compact than the other tables. This one only adds about 5" beyond the width of the stock wing to the left of the blade. That's with its miter fence removed. So it doesn't dominate your shop when you're not using it.
I should add, this sliding table can be used when your saw is on a mobile base since it only bolts to the saw and doesn't require permanent outrigger legs unlike other models such as the excalibur.
One more thing, I use the exacta TS-III fence on that saw so I just slid the rails 9" to the right.
I couldn't live without a sliding table anymore... I'm spoiled!
Scott in Montana
