ADVERTISE HERE - FREE TRIAL
Carved Coffee Table II-Part 5 FINISHED *LINK*
Alan Young
Alan Young
Hi Friends,
I finished the Coffee Table last week and took some pictures of it at my neighbor's house yesterday afternoon. Before posting the finished shots, I want to share one more set of pictures from the Shop. These show the finishing process- The final look and finish is no doubt not to everyone's taste. The gilding wasn't in my plan till way late in the process -even then I hemmed and hawed a lot over whether or not I should...I decided that I had the 1st coffee table with a single finish all around and that this was the one to set at full blast....:^) Here goes.........
The table is ready for the finish. I'll employ a multi-step process involving these products.
Sealcoat de-waxed shellac to seal the inlays,
Super Brass Mica Powder and Clear Shellac for gilding,
A Red Mahogany Stain for a base coat stain on the base and the top,
A mixture of Tung Oil finish and General Finishes "Nutmeg" gel stain to tone the base only.
Polurethane for the top coat of entire piece.
The top will get a coat of red mahogany stain. I don't want the light inlays to get stained so I start by sealing them with de-waxed shellac.
The next step is to gild the routed profile of the top and the carved elements of the base. The gilding solution is a mixture of Mica Powder and clear shellac. There isn't a real formula here-it's just a matter of how dense a gilded texture is desired. I want the gilding to sparkle but not totally cover the grain pattern.
I use an artists brush to apply the gilding to the edge. I want to cover the entire edge but not the top surface. If any gets on the top I just let it dry then scrape it off with a sharp chisel.
The edge is gilded, and the inlays are sealed.
The shellac/gilding solution drys within a half hour so while the top sets I move on to the carved elements.
The gilding on the base is finished.
Next- I brushed on the red mahogany stain then wiped it of quickly. I couldn't take in-between-shots as I didn't want the stain to set too deeply especially in the top.
The stain went on quite dark and covered the gilding and inlays but because of the shellac base on those elements, after wiping off the stain, a nice contrast is revealed.
After wiping off this first stain coat I let the table set over night. The next day I made a glaze out of Tung oil varnish and the gelstain. This was applied to the base only and there just to the non-gilded sections
I let this set over night and then the next day applied 2 coats of Gloss Polyurethane.
More finished shots can be seen at the link below.Thanks for looking-
Alan
MORE FINISHED PICTURES
Re: Carved Coffee Table II-Part 5 FINISHED *LINK*
Stunning!
Stephen Kirk
John Pappas
Nice work, Alan. Thanks for the details on the finishing. I am curious....any particular reason for using tung oil instead of LO in mixing the glaze?
John
HC Sakman
Lots of tedious work Alan. Nicely done and proved that you are a patient man! I guess every man can be patient for their passion.
Chico
Alan Young
Alan Young
John,
Although I haven't specifically avoided it, I've never really sought out BLO for my finishes. The finishes I've sen with BLO seem muddy at times. I wanted to tone the color-hence the gel stain but I also want some semblance of the wood to come through too...
Alan
Alan Young
Expectations
Alan Young
Thanks Chico ,
I found it necessary to remind myself of several things.
Don't be in a hurry...
When I think I've finished an area or specific task-Be prepared to do more...and more....
Take pleasure out of small incremental progress.
I also found my expectations of what is acceptable to change. The first two fleure de-lis carvings I did were replaced after I finished the third and fourth-Mostly because what I thought looked good on the fist two was didn't match up to the 3rd and 4th.
Alan
Just My Opinion
David Yoho
I think you did a wonderful job on the table and, as you said, it's for your son who will love it and that's what counts. While I can't say I'm a big fan of the gilding and the glossy finish, I really like the style and shape of the table, aprons, and legs. I think I'm just too overwhelmed with how "busy" it looks. Between all the inlays and the gilded edge of the top my eye is confused. Sorry, just my opinion and not meant to offend.
I'd love to see that same table with no gilding, a slightly different finish, and only the center inlay. That would allow the viewer to discover the carved elements and great looking legs while they're enjoying the graceful style of the whole thing.
David
Alan Young
Which is shared by others...
Alan Young
My wife is glad to see it going to my son's house.
What do psychiatrists call the fear of being covered with gold paint? A gilt complex
