We value your privacy.
I have high-speed internet through Comcast. Lately, my internet goes down daily for about an hour, usually in the afternoon. The signal goes through a non-wireless router that's probably 6-8 years old. Can routers go bad and need replacement?? I also have VOIP phone service as well, if that helps.
what kind of router Linksys WRT54G ?? that is the kind i have I am not with comcast My frend across the street has a linksys and comcast and it work's fine the router works or it doesn't In the router set up go to internet exployer That is the blue E on desk top open it up Put 192.168.1.1 in the location window Now a box will come up asking for a user name leve that blank go to pass word and type in their admin than click ok that will take you to the linksys page Not knowing what you have in their Kind of hard to help The best i can tell you is call linksys or camcast and see if they suport linksys router's
That sounds like a Comcast issue. From your description, the router/connection works most of the time with just an hour break in the afternoon. If that is the case, there should be no reason for the router to shut down for an hour every day. Sounds more like something outside. Do you by any chance run a firewall that has a setup to block internet access during certain times? If you do, and it somehow got set, that could cause you the problems.
One other question: When it does not work for the hour or so, does it just not let you on, or will it kick you off if already there?
You ask if a router can go bad -- I suppose they're no different than anything else and it's possible. However, that doesn't sound like it's the problem. I'd contact Comcast and see what they say. It sounds like the problem is on their end.
In my area I've noticed we lose our wireless connection often enough to make me need to re-boot the wireless router from time to time. I'm not sure what's going on but it's getting to be annoying. I'm pretty sure there's nothing wrong with the router.
Add to that Comcast just "enhanced" their TV service by converting many of their analog chanels to digital and sent out up to three converter boxes that don't work with the TiVo DVR we have and I'm getting more and more unhappy with them! I have a new TiVo coming that along with a cable card from Comcast will do away with the need for their converter and allow us to get back to doing TV the way we like it.
The router either works all the time or does not work at all. Now other things can cause the equipment not to work properly ex. communications link going down, incorrect setup of router/firewall, ISP dropping IP address, etc.
A couple of questions though:
Does this router have a firewall incorporated within it?
Does the communication link go down at the same time during the day?
How long does the (link remain/communication link remain) down?
Do you lose your VOIP service during the same period that your data connection goes down?
Does the VOIP share the same comms. link as your data communication link?
Currently what do you do to successfully reconnect to your ISP?
If you have the type of cable modem Comcast seems to use around here (Scientific Atlanta DPX2100 I think), you can check the signal levels and connection status directly with your browser. Type http://192.168.100.1, user name admin, password w2402. If it's a different modem there is a page on the Comcast web site that gives all the user name and passwords. (or call Comcast support)
When the connection goes down, try this. If you get no response, you can plug the ethernet cable directly into the modem and bypass the router. Comcast support can also do this remotely. (They should know if the problem is on their end.) I've found them very helpful for debugging things like this.
This status test will also tell you the quality of the signal. At the moment, the downstream Power Level on mine is around -1 dBmV, signal-to-noise about 35 db. The Comcast support web site has a page that explains the range of numbers you should see for each parameter.
For a while last year I was having all kinds of problem with dropped connections and extremely slow data rates. The best downstream power level I saw at that time was -15 or lower. During the times when the cable cut out completely the power level dropped to -30 dBmV or so. Two Comcast techs came and checked out everything, replaced a questionable piece of cable in the yard, tested the underground line to the pole (I have about 600 ft underground to the street), and found a bad section of wire on the pole and had it replaced. I've had zero problems since.
