clean foam off concrete
mike mcnerney
I suppose I should be putting this on concrete central but here goes.
I pulled old carpet & underlay off a basement floor & some of the foam underlay is still stuck on. I want to paint it. Here what hasn't worked. Alcohol,varsol, acetone, tsp. Although the acetone softend the old paint on a very rough concrete surface. I am considering grinding, sanding, maybe muriatic acid, though unfamiliar with that.
Any ideas?
cheers
Mike McNerney
Re: clean foam off concrete
First, Ventilate. No matter what you do, you're going to need serious air-change to avoid serious do-do.
1. Hand scrape off what you can [don't forget the knee pads].
2. For a solvent removal - first turn off all pilot flames [water heater, furnace(s)] as most any solvent will tend to accumulate at low levels and can reach flash concentration before you realize it. On small area try mineral spirits or naptha with exhaust fans going and a route for make-up air. This will not be a situation of pouring it on wholesale and just removing the residue; scraping and wire brushing there will be.
3. Acid is unlikely to help because the foam fused to the surface will keep it away from the concrete surface. Muriatic will, however, do a fine job of filling your basement with free chlorine gas.
4. Concrete grinders, other than "spotters" run on 7" angle grinders, are usually gas driven, so the CO and smoke concentration are likely to make a short work-day of it, and the grind "stones" will get fouled with the rubber/foam residue rather quickly, not to mention the abrasive dust that can and will penetrate and wreck most any machine and motor within the area. Significant water will have to be used in any grinding to moderately control the dust.
Wish I could be more helpful, but I've been there and done that and it was not a pleasant several days. Were I doing it now, I'd call in some young guy who knows more than me. There are enough of them around, I'm sure
Clint Searl
Clint Searl
The foam may respond to a coarse wire wheel brush chucked in a corded drill followed by flooding the areas with a strong lye (Drano) solution.
Clint
Long handled scraper
Gary Camp, Bend Oregon
If you have a good carpet supply store look for a Crain #375 floor scraper (maybe you can rent one someplace). these have an adjustable length handle so you don't do a lot of bending. The blades are really sharp but they do a clean job.
glc
Oh yeah wear gloves
It can be blister city even for the toughest hands
Re: Oh yeah wear gloves
Justin Szeliga
Do a google for carpet supplies & find a good commercial supplier & they will have a stripper that will loosen things up. Or get on a dust mask, full face shield, & use an angle grinder as mentioned.
It won't be fun.
Peace
Justin
del schisler
I did a google search and here is one item that was their may work ? than at ace hardware another thing that is sopose to work http://www.acehardwaresuperstore.com/jasco-adhesive-remover-for-old-hardened-adhesive-p-5630.html
Replacing a carpet on a floor involves a lot of hard work, especially if the floor underneath the carpet is concrete. There are different ways people can use to remove carpet padding from concrete, some easier to do than others. One way is by using boiling water with a sharp tool to scrape padding glued onto concrete, which is an effective method that is less time consuming as well as inexpensive.
Prep Work
Remove majority of the padding by using a snow shovel. Be careful not to put abrupt force to prevent causing damage to the concrete. Remove the tack strips used if there are any by using a smaller sharp tool such as a wide bladed putty knife. Remove as much debris as possible such as all the loose pieces of padding, dirt and tacks by using a push broom.
Boiling Water Method
Use a deep, big pot to boil water. Wear rain or garden boots to protect your feet from the splatters. Pour the boiling water onto the areas with remaining carpet pads not removed by the initial scraping. Let the pads soak until they start to loosen. Use the snow shovel to remove the loosened glue and padding. Use multiple pots to boil more water if you have a large area to work on. This way, you will not waste time waiting for water to boil. Use the putty knife to remove smaller pads. The boiling water method is effective because the heat coming from boiling water helps dissolve or loosen the glue. The water also helps soften the pads, making it easier to scrape them off.
Other Methods
Use heat gun and scraping tool combination to remove carpet pads off concrete floors. The heat gun can help speed up the removal of carpet glue; however, it is more time consuming than the boiling water method because you would have to heat one spot while you scrape. It is also bad for your back and knees because you would have to be kneeling down and bending more often to get closer to the glue.
Another method is to buy solvents or chemicals to remove glue; however, some chemicals emit fumes. Make sure to open the windows to ventilate the room to get rid of the fumes that chemicals emit. This may be a problem for basements, which only have small windows at best. Another disadvantage is that you would have to buy the chemicals, which can add up to your costs, especially if you have a big area to work on
Electric buffer
Ray - Middletown, IN
The kind used to buff vinyl floors. Rent one for the day and use either an abrasive disk or scrubby type disk (both available from the rental place). No fumes and should be finished enough for the next step. Raise the handle to move one way and lower the handle to return. They are probably 16-18" in diameter and will make quick work of scrubbing a concrete floor.
Ray
Re: Electric buffer
mike mcnerney
Thanks all. I ended up after some scraping, sanding the small stuff with my 5" RO & 60 grt.
It wasn't absolutely everywhere, just 3 long lines. Then boiling water & a wire brush pretty well did it.
Mike
