Veritas - Innovation in Tools
MDF
MDF
MDF
Danny P
I'm working on a project that calls for a 20x20 piece of plywood with an 3/4x3/4 edging of oak. My question is, can I glue the 3/4 edging to MDF sheet stock without any screws or fasteners? The only reason that I'm asking this question is because MDF is what I have on hand.
Thanks for any comments and or suggestions.
Re: MDF
Re: MDF
pecker
I do it all the time. No problem.
Re: MDF
Yeahbut
a) use biscuits if possible
b) "size" the MDF edge with some thinned glue a day before the glue-up. This will control the MDF's sponge effect that will, otherwise, such glue away from the joint surface and give you a weak bond for the wood.
I cut the slots first, then size, and let dry. You can then use less glue on the biscuits in order to reduce or eliminate telegraphing them to the top surface.
Re: MDF
Me too
awleonard
I've done that many times. I don't do anything special - just glue the strips on with yellow glue. MDF is great for some things.
Tony
Re: MDF
Re: Yeahbut
Dick Coers
I like to size as well, but just before the glueup. I use full strength glue to "paint" the MDF. When I fell it get real tacky, I put on another coat, glue up and clamp. That end grain MDF is a sponge for certain!
Re: MDF
Re: Yeah But
On the few occasions I edge glued something to MDF I coated the edge of the MDF with a liberal coat of yellow glue, let that soak while I put a coat on the other pieces and then put them together and clamped. The MDF soaked up a lot of glue and it became tacky pretty quick but the other glue seemed to wet it and it worked fine. Don't know of any failures. Done the same thing with plywood, but used less glue. Would not have thought of using the half strength glue size. Sounds like trying to glue to dried glue and did not think that would work. Learn something everyday here.
Re: MDF
Glue Sizing
Did several platform beds in MDF with high gloss lacquer finishes. Used the glue to seal the surfaces to be painted with several extra coats on the end grain, resanded, and finished. Lacquer came out like glass. On glue joints the final application will soak in as well, but it won't wick away from the joint so the joint will have a better cure and more strength.
Re: MDF
Re: Glue Sizing
Danny P
Thank you all for the comments.
