Delta 12" disk sander problem
Starry S Chan
I just bought a used Delta 12" disk sander. The disk is not flat. This is a 1/64" (~ 0.015") dip towards the middle of the disk.
I am think about taking the disk out and have a local machine shop true the surface. Do you know how I can take the disk out?
Is there any other way to true the disk?
TIA for any tip.
Starry
Re: Delta 12" disk sander problem
Tom MacGregor
Have you tried it out yet? Most of my disc sanding isn't right near the center of the disc. I'd make sure it was actually a problem during use before trying to fix anything. If it's worn or warped I'd check the price of a replacement disc. If you choose to get it flattened ask the machinist if removing up to 1/16 could make the disc too thin to remain stable or throw it out of balance. The discs I've seen are attached with one or two set screws and occasionally have a keyway.
Starry S Chan
I am using this disk sander to correct minor problem with my half rings in my segmented turning. I use a sled to cut the pieces so I may only need to use the disk sander to correct mating problem between two half rings. In this case, the two legs of the half ring straddles the center.
I tried it this afternoon with a test ring and I was unable to get the two half rings joined perfectly. I will retest this tomorrow with a perfect edge to check the evenness of sanding across the disk. It could be a technique issue. But it bothers me when I know that the disk is not flat.
Starry
