Pocket hole joinery for table top
Gregg
Hi,
I'm in the midst of using some 1" reclaimed mahogany to make a table top. Does anyone have advice on using the Kreg system to join the edges together? Will the wood movement be an issue?
Should I stick with biscuits?
I'll definatly use pocket screws to attach top to apron.
Thanks
Re: Pocket hole joinery for table top
Andy Wright - Allen, TX
Personally I would just glue it with no fasteners.
If you use biscuits, you are supposed to wait a few days before you sand it flat so that he swelling from the biscuits can go down. I have never had it happen to me personally, but if you sand too soon there is a possibility of being left with football shaped indentions
I agree with Andy. If you joint the edges carefully so the joint is nice and tight, glue is all you need. Titebond and its competitors is stronger than the wood. The entire furniture industry relies on it to be stronger than the wood and it is.
I use biscuits occasionally to help with alignment. If I am working alone (usually) and I think the glue up might be a struggle I put a few biscuits in the joint just to cut out some of the slipping ans sliding. I seldom put glue in the biscuit slots. IF the biscuits are dry, you will avoid the issue of the swelling Andy mentioned. I am not particularly careful about it and I assume some gets in there anyway. At the slow pace I work, waiting for the glue/biscuits to dry/shrink is no problem.
I don't like pocket screws as much as I thought I would. They are excellent and work exactly as advertised, but if you ever make a design change and hit one with you favorite saw blade you will find out why I am judicious with them.
Be careful to design your top to frame attachment to allow the top to float. A couple of pocket screws near the center of the top into the end rails make a good start, but down the sides you need to allow for expansion and contraction of the top. If you use pocket screws near the center of the side rails you Amy find the rails bowing with seasonal changes in the top. Of you use them near the corners, something may burst.
George Colonel's Workshop-Havertown PA
Good Afternoon Gregg,
I am in full agreement with the other responders. Glue alone is all you need.
George
Roy Anderson
I love pocket hole joinery, but not for things I expect to be an heirloom. Pocket screws are quick and easy, but not all that strong. For the tabletop, I have to come down on the side of all the other commenters here. If you joint the boards well, glue is all you need.
Isn't that what the Beatles said? Glue is all you need?
Dave Paine
I agree with the others about only needing glue for the strength of the joint.
You do not state if you have sufficient and wide enough clamps to keep the sections to be level.
I will use 2 or 3 dowels along the joint for alignment horizontally and vertically.
I have invested in clamping bar sets to allow me to keep the sections aligned in between the dowels.
Wood being wood is rarely exactly straight, and even if straight today, may be less so tomorrow.
Even a small e..g, 1/16th difference of height across the joint is time consuming to remove.
