THE WOODRAT IS BACK!
Windsor repair
Windsor repair
Windsor repair
Gary Smyth
I�ve painted myself into a brain stoppage. I have this old Windsor Chair where (bless the little children) the bow cracked and shattered. I made a new bow, bent, and tapered it to fit the arms. I left a 1/16� flat centered on the bottom of the bow to provide purchase for a bit when drilled. The spindles (tapered to 5/16") and splat (tapered to 1 7/8") are of different lengths and do not pierce the bow. Here is my problem. I can�t get my mind around the angle to drill the holes on the bow for the mortised splat and spindles. Maybe I should have drilled first and then tapered. The back angle is 12 degrees and the splay for the spindles varies. I have attempted to build a jig so I can use a flat bottom Forstner bit, but on both tests I seem to set the angles wrong and drill poorly when I remove the test bow from the chair and it is placed in the vise jig. I get it all bassackwards. Also because the bow is both bent and tapered the centered 1/16" flat is no longer centered on the bow except at the splat. The capture depth for the mortise is 5/16� maximum. I could eyeball it by hand, but for certain the angles and depth would vary--perhaps too much. I'm losing confidence daily. Hey, chairmakers. What am I not grasping? This seemed so simple until I made the attempt. I bet a Windsor Chair person could do this in fifteen minutes. Suggestions please. Pics.
Re: Windsor repair
Re: Windsor repair
I typically drill all of my hoops from above. It is easier that way.
Here are some thoughts (take them for what they are worth).
My drilling jig has a sleeve - I insert the drill bit into the sleeve.
The wings on front and back hold the sleeve and the jig in place on the hoop. I have an offset round "plug" that fits into the spindle deck holes.
The top part of the jig can slide on the vertical support. I tighten the jig clamp to "lock" it on the vertical support.
If you were to make a "clamp" to secure it to the bottom of the spindle, you could use a similar jig and drill from the top.
Re: Windsor repair
For the splat...
I typically get out my bevel gauge and determine the angle at the top. I then chisel and knife out the splat mortise. I typically do two tenons at the top, not a single wide one.
Re: Windsor repair
More jig pictures?
Jim in N.VA
Your drilling jig looks very clever, but I'm having trouble picturing the whole thing. Do you have more photos you could share so I could understand?
Re: Windsor repair
I'll try for a verbal....
Camera is elsewhere.
The vertical shaft is a piece of oak that is about 36" long - heavily waxed.
The sleeve is in another piece of oak. There are oak spacers on either side of the shaft. All of this is secured with two pieces of plywood (and lots of drywall screws). At the bottom, I've got similar spacers. Where the sleeve is positioned in the upper, I've got a tapered dowel with a small finishing nail embedded in the center. This fits into the holes in my spindle deck of the chair. I lay out the hoop and sight through the "cross hairs" to drill.
Sometimes you have to drill through the hoop and then drill the spindle deck holes to get better angles. That's what the nail is for. When I lay out the seat and spindle deck, I mark the drilling positions. Typically these are done at a particular angle and sight line (say 10-15 degrees). The nail is for the ones that can't be predrilled, but have to be drilled through the hoop.
Re: Windsor repair
Re: Windsor repair
Gary Smyth
Thanks for the look and help. Just to be sure, you state "If you were to make a "clamp" to secure it to the bottom of the spindle, you could use a similar jig and drill from the top." Do you mean bottom? If I build the jig and secure it at the bottom I would drill from the bottom of the bow, correct? Also you say you have an offset plug to fill the holes. How would you make an offset plug? Would I angle the top?
Re: Windsor repair
Re: I'll try for a verbal....
Carol Reed
Not planning on a chair, but I love jigs and love to see how they work. I too, am having difficulty visualizing your jig, JL.
Often close-up pictures tell us a lot and not enough. Here photos from further away to show the entire set-up would help the close-up shots make sense.
Just a hintn for when you find your camera again. ;)
Re: Windsor repair
Re: Windsor repair
You would secure the jig to the base of the spindle to drill the hole for that spindle. When I drill a hoop, I put the bottom of the jig into the corresponding hole in the spindle deck. Obviously, your holes are full of spindles :D . So, you would have to clamp to the spindles rather than use the holes as I do.
The offset plug that I mentioned is a tapered dowel that fits into the hole in the spindle deck. It is inline with the sleeve for the drill bit, but offset from vertical piece of oak.
You always drill from the top of the hoop. You also clamp a sacrificial piece to the bottom of the hoop so that you won't splinter it as the drill bit exits. The sleeve guides the drill bit. For your application, you would replace the bottom piece of the jig with a clamping arrangement to secure it to the bottom of your spindles.
Hope this is clear.
