recessed shelf question
bbuilder55
I have a recess in my wall going from the floor to the ceiling. It is 12" deep and 31" across. I want to put shelving up in the recess by using some small metal angle 1/2"w X 3/4"long x 1/16"thk. The drywall I want to attach to is not straigth. It bows in the middle and goes back at a slight angle. Should I sand the side and back of the boards to conform to the shape of the recess or should I keep the boards straight and make them just long enough to fit? If I sand the boards they conform nicely but I notice the boards are mishapen when I hang them. If I leave the boards straight I notice a gap between the boards and the wall due to the inconsistancies of the drywall. Which method will look more professional?
Re: recessed shelf question
I think either method would work, but in the long run it would look better if everything were straight and square, plumb and true. What would it take to flatten the wall in the recess? Could you fill in the "low" area with Sheetrock compound? In effect, plaster one or both side of the bulge to eliminate it.
I once built a house that was on many different levels. There was a ripple in a wall at one of the level changes. We took the drywall down and worked on it and it was better, but still visible. I paid a friend of mine who was a plasterer to fix it. I thought he was going to use all kinds of fancy plasterer tools like long trowels and screeds and straight edges. He came out with a bucket of Sheetrock mud and a six inch knife. Picked op a stick out of our scrap pile and sited it for straightness. Applied the mud to the wall in the low places, struck it off with the corner of the stick and said, "There, when that dries, sand it and paint it."
So it might take you several days to build up several 1/8 thicknesses of drywall compound and get them flat, but once its done you won't be agonizing over whether to curve this or that.
chrispy0623
By the time that you have "Stuff" on the shelves, no one not even you, will ever notice any gaps, so don't sweat it! Leave the shelves straight!
Chrispy
FredD
For what it is worth , any housing I was associated with the building of, in the closets and pantry areas , the shelves were always scribed and cut to tfit the wows in the sheetrock , if there were any.
Anything less then that looked like a slambang approach to the interior trim.
FredD
