OT - Will it ever end??
It is the 2nd of March. It is snowing again. I like snow - but it is March 2nd. Sigh. I want to plant some things. I've got seed and planting catalogs open and dog-eared.
Any moment I'll expect a glacier to start forming on the mountain near were I live.
Re: OT - Will it ever end??
Blame It On Global Warming
Tom Rex in TX
Actually, that's correct.
Rod Peterson�Ormond Beach, FL
I don't want to second guess your thoughts in posting that subject line, as you might very well have meant it tongue-in-cheek, but, in fact, it's true. Not, however, in the sense that "global warming" deniers mean. Since "climate change" is the more accurate descriptor, it's a more helpful way to understand the phenomenon. Here's one of a gazillion links available to explain it: How Heavy Snow is Evidence of Global Warming
Let's not start a political debate on Gore v. Inhofe here. Do some searches and find out for yourself, and let it go at that.
Rod
Howard Norman
We have had a lot of snow this winter but that was predicted by the El Nino effect not by the Global Warming Crowd. Using the El Nino and La Nina theories has been much more correct for my little part of the world than anything else in predicting long term weather conditions. YMMV of course.
Spring will come and then summer, it seems to happen every year for some reason, followed by fall and winter. Some winters are mild, some are severe. This happens to be one of the severe ones for many of us.
Common sense
Craig Daymon
If you melt more snow at the poles, that puts more moisture into the atmosphere. More moisture means more precipitation.
Considering that the global warming spoken of has only talked about a less than 5 degree AVERAGE change in temp, that is not something that impacts whether it is going to snow in winter. We only need it to get to 32 degrees. Most of these snows have been pretty wet (closer to 32 degrees, 0 for you celcius guys).
I've always thought that the better approach to selling what they are trying to do with the global warming debate is to reinforce just how much better it would be living in a world where the sky is still as blue as it should be, where you don't see a cloud of brown floating at the horizon when you fly into almost any airport. As woodworkers, we breath in enough that we shouldn't, so we can use all the help we can get.
Energy
As the atmosphere warms, more energy is available to "power" weather systems. Whether El Nino, or 'canes, or tornadoes, or nor'easters, these normal events will continue, but they will become more intense. The history of the planet is one of constantly changing climate when viewed over time. Notwithstanding our self-image, the vast majority of humans aren't very good at that view.
Change will come, with our help or without it, but we don't have to accelerate it while we learn and evolve in time to deal with it. Then again, there is a self-destructive element in "human nature" that may work against us.
There have always been the "CO2 is natural" types running around who will insist on driving their 4-ton SUVs while Bangladesh and New York submerge.
George Colonel's Workshop-Havertown PA
Good Afternoon JL,
I saw on the news last night, that we in Philly receioved 71 1/2 inches of global warming so far this winyer. About the only thing to plant is a snow shovel. I have some harvested seeds from last summer's hot peppers and tomatoes and will probably start them in an egg carton or two within a couple weeks. The sooner it gets warm, the sooner I quit shivvering.
George
Re: Energy - Thank You!!!
Ed Beck
I�ve shied away from discussing energy when talking with people who refuse to accept the data. Thanks for bringing it up.
The issue is that there is more energy being retained in the earth�s atmosphere. One of the results of this is an overall increase in temperature, which is an easy thing for people to latch onto and repeat time and time again. When it snows in the spring, people who have latched onto that one facet of climate change point out the obvious fallacy of �global warming�.
I recently got an email from someone on the east coast saying that the only good thing about the snow was that it kept all the �Global Warming Nuts� quiet. I just pointed out that here in the Pacific Northwest we just had the warmest January since they started keeping records in 1891 (date approximate) which exemplifies why you cannot use short-term, localized weather as proof one way or the other.
Weather is hugely complex, and we don�t know what individual events are going to happen with the increase in retained energy. It is quite possible that part of the Northern Hemisphere could become colder. Take the possibility that the increase in energy retention in the Pacific forces the jet stream further north during the winter where it would pick up arctic air. The energy dissipates over the North America land mass and the jet stream drops back to the lower latitudes bringing the arctic air with it.
Is this going to happen? I don�t know. It�s a possibility.
By the way, you can help with climate prediction models by loaning your computer to Climate Prediction Net when you�re not using it. This is an application much like SETI at Home, in which your computer gets a little piece of work to do when you�re not using it. Please see http://climateprediction.net/ for more information about this project.
Should also mention we're spinning faster
Craig Daymon
Turns out the earthquake in Chile caused a change in the planet such that our days are now 1.26 microseconds (0.00000126 seconds) shorter. We are spinning faster! Hold on tight! Article link below:
http://www.businessweek.com/news/2010-03-01/chilean-quake-likely-shifted-earth-s-axis-nasa-scientist-says.html
-Craig
Re: Energy
"People" have no clue about how much energy is required to raise the average temperature of the planet's atmosphere 2 degrees; they simply can think in terms of hundreds or thousands of nuclear bombs going off. They also don't understand that weather systems are driven by heat (or the lack of it). F-5 tornadoes and Class 5 hurricanes have been rare in the past. Maybe when they become common, people will start trying to learn and understand.
Maybe.
But it might just be too little, too late. for a whole lot of humanity. Of course, there are those who would welcome such a scenario, but will never admit to it.
Not To Worry
As the ice caps melt, adding the weight of their water to the equatorial zones, the spin will slow down far more. Which will be a good thing because the fresh water will have shut down the Marine Salt Conveyer, withholding heat from the poles and bringing on the next ice age.
Slower rotation means more chance to melt the glaciers approaching Atlanta. ;)
Our onions, carrots and radishes are sprouting
Phil Joines
and the lettuce, broccoli and cauliflower are in the ground (barrels actually). The potatoes will go in this week, I'm running late on them. It's hard to work our clay when it's so wet.
We're covered again
Andy Halterman
Seven more inches of snow here today. That brings me to a total of 34 inches at the cribizzle so far this winter. By far the most I've seen in my 12+ years here in Hendonesia. We average around 14 inches for the winter.
I actually was able to ride my mtn. bike on Sunday. That was the first time in six weeks. Needless to say, I'm looking forward to getting some trail time.
Andy Halterman
Thankful I bought a 4wd vehicle a couple years back in Hendersonville, NC�
Arctic Inversion
Jorge Casta�eda
Hi Rod,
I agree leaving politics out, I think the technical term for the kind of winter we are having is called arctic inversion. When one of those is acting, other places can have more snow and cold than the arctic circle. Just like Europe this winter.
Jorge
Jorge Casta�eda
Colonel,
with due respect, just relax and conserve energy, stop shivering :D
Jorge
Was in the 50's here...and
Craig in Silverdale
this is the Pacific North West. The low last night was warmer than our usual high.
Call Algore and give it to him !
steve mackay
Bill White
Coldest winter in Mississippi since the '30s.
This Global Warming is killin' me.
Bill
