OT Allergy Question
OT Allergy Question
OT Allergy Question
I know we have talked about wood allergies and I have some. We have also talked about dry skin and I have that too.
I bought some Micro-fiber bed sheets. Supposed to be softer than Egyptian Cotton. (I had 400 thread count Egyptian Cotton before). Now my ankles are tormenting me. Patches that turn pink or red and I would happily scratch until they bleed.
So is this an allergy or has the dry skin reappeared? Or both? What is a micro fiber and could I be allergic to them? Could it be the starch or sizing in the sheets? I did not wash them before using them. Anybody else got experience with micro fibers?
Re: OT Allergy Question
Microfibers are typically polyester, nylon, blend of polyester and nylon or copolymers of polyester and nylon.
You aren't ingesting the microfibers. The components are not likely to diffuse into your skin (WAY too large). It is possible for an allergic dermatitis to happen as the microfibers are exactly that - microfibers. If you have cracked or broken skin, microfibers that shed off of the sheets might get into your skin and trigger an allergenic response. Possible is the word - likely - I don't know.
As it is winter and microfibers are known moisture grabbers you may be wicking the moisture away from your skin and drying it further - making it itch more. I've got a pair of microfiber gloves that dry out my hands tremendously. I always have to put moisturizer on my hands after wearing them.
Howard
Barry
Have you tried Aquaphor cream. I have dry skin and it works for me, just a maall amount keeps skin moist. Use it right after taking a shower and when needed.
Howard
FredD
Barry,
you know what it is , dry skin itch from dry air, every Winter , plan on it, raise the RH in your house and use moisturizer and your bed won't look like your killing chickens on it.
FredD
Dick Coers
Not discounting the dry skin idea, but it may be something else. I have developed allerigies to several foods that I eaten all my life. Wheat will make me sick, but corn has become the heavy hitter for me for itching. A nice tall coke will even do it with the corn syrup in it. I have areas behind my knees, my ankles, and middle chest that will itch when I eat these foods. You might try an antihistamine to see if it will ease the irritation. For quick relief, there are some anti-itch cremes that I think have antihistamine in them. Skin irritation is rough on sleep quality too. I find myself waking up itching those irritated spots. This getting old is a real adventure!!!
Not to be a dick, but..
Dave Bair, Eaton Rapids, MI
if you're itching only on your ankles, you may have fleas in your environment; specifically, cat fleas. I know this from actual experience, so don't ask.
Dan Donaldson
How about a new acronym: GOINFW
(getting old is not for wimps) ;)
I can identify with this, big time.
WASH THE DAMN SHEETS
Your issue could be with the "sizing" or packaging or any compound used in the manufacturing. While you're at it, do the mattress pad and the blanket. It's common, but bad, practice to allow skin contact with any cloth before it is cleaned. The sheets may have even been pre-washed with a product to which you're sensitive, although I'd expect your face, neck and hands to exhibit the same symptoms.
Had an uncle who, after his wife died, figured he could wear his new briefs without washing them first. Took 2 MD visits and more than a week for the rash to subside.
New shoes by any chance?
Sure its not chiggers?
George Colonel's Workshop-Havertown PA
Hello Barry,
I have dry skin, red itchy rashes splotching over ankles and arms and lower back. This has gone on for years, and I've seen a lot of dermotologists, had patch testing, tested sample creams, and am still living with it. When the conditions become extreme I take prednosone which knocks back the rash and itch in short order. But it is a steroid by prescription only. there are other steroid based creams which your doctor can prescribe. A little goes a long way, as these tend to make the skin thinner. I use the crteam sparingly, and over coat every area--especially ankles-with petroleum jelly. Sleep can be a problem. Atarax helps, but knocks me into a state of dumnation for a day or two afterwards. I too am going through it. Good luck.
George
Myra Fox
One who has allergies, even if they have not previously manifested themselves in skin reactions, should ALWAYS wash clothing/bedding/anything that will come in contact with the skin before using it. What it sounds like to me is a bit of eczema brought on either by a dye in the fabric or by the fabric itself. You won't know until you wash the sheets. If I were you, I would not use them (even after washing) until your ankles have had time to get well.
Aww..that takes out those square wrinkles! (NM)
Grant in Iowa
Wow, What great information
Glad I asked. I Googled microfiber allergies and got a ton of info that indicated it was the best thing since sliced bread at keep dust mites and pet dander and other horrible stuff at bay. Not a single mention of the possibility of dye or sizing or the fact that it might wick the water out of your skin.
Guess I will be washing them. I was just hoping to save a little water by getting a month or two out of them first. (Just kidding) They get washed once a week whether they need it or not.
Re: OT Allergy Question *LINK*
Herb Yost
Might bedbugs be a possibility? Those things are becoming epidemic over the US, appearing even in the best and cleanest of homes. if you've travelled recently or have had guests, for example, those little suckers can get into suitcases, clothing thrown on the floor of motels, etc etc. See the following link for some information.
http://www.ca.uky.edu/entomology/entfacts/ef636.asp
