I can't figure out how to make this
Roy Anderson
I have a piece of wood about 10" long, square in cross section. I want to make an even 10 sided rod out of it.
How to go about this.
Roy Anderson
Re: I can't figure out how to make this
Ed Mulligan, Cape Cod
If you are adept with a hand plane, construct a couple of decagons on manila folder stock, glue them to the ends of your piece being careful to put them in the same orientation, and plane the stock down to the templates.
If you want to do it by machine, one way would be to construct a series of cradles to hold the stock as it is passed through a planer. To use a planer you will need stock longer than 10". Start with a 24" piece for ease of handling. Off hand I don't know how many cradles you would have to make to accomodate the lower surface, but there will be several. It's a lot of effort unless you need many feet of the stuff.
If the stock is big enough, say 3 or 4 inches square, you could do the work on a table saw. You would need a big piece in order to secure it well so it doesn't come lose during a cut. Make a sled to hold the piece, cut, rotate, secure, cut etc.
Re: corrected link to decagon *LINK*
Bob Entwisle in NJ
Sorry, my previous link was for a dodecagon.
Ellis I love the new 'delete' feature!
If two of the flats on the decagon are aligned with the flats of square blank, I can see making this on the tablesaw with the blade set for a 72 degree angle, and ???.
I haven't tried this, am just thinking out loud.
I may have to try it later to find out how wrong I am.
Bob in NJ
http://en.wikipedia.org/wiki/Decagon
I know this is not what you asked, but would you accept staved construction? I have made many "tubes" by ripping strips/staves with 18 degree (for your example) angles on each side and then gluing them together. Lay them out, wide side up side by side, tape them together, turn them over, put glue in the vee grooves, roll them up and clamp them with hose calmer or strap clamps. I was them mounting them on the lathe and turning them into cylinders and making bird houses out of them.
I think you could do it on a table saw with a solid piece of stock. The first six since would be easy. Look at the picture posted above on Wikipedia. There is a flat up and down and a "point" to the right and left. Set the blade to the angle required for the flats just above and below the "points" and run it through the saw four times. Might take a cradle to get the other four flats because they angle is beyond the reach of the angle of the blade.
If you have a lathe with an indexing head you could turn it into a cylinder, then index every 36 deg and use a router to make the flats. Have to build a support like a shelf to position the router above the lathe but that should be fairly simple since the flats wouldn't be wide (as if surfacing a table top).
I thought about using a lathe with indexing head also, but I don't think mine will turn to ten positions. I think it has 36 stops. Maybe some of them do have the right number.
I like John's idea! If the proper index head is not available, you could make one from a plywood disc and attach it to the stock. Rig up a way to lock it in place for the router cut. You will need a longer piece of stock so the lathe parts and index head don't interfere with the router.
